Overheating Problems
Guest JARushby
Guest JARushby
I have a problem that is now starting to mystify me.
Basically the car's temp guage never used to move from half way. If I leave it ticking over it still doesnt. If I cruise around at a reasonable pace everything is fine. However if I accelerate hard or uphill the temp guage rises quite quickly to the red (or just beneath), if I ease off over th enext minute (probably less) it returns to normal.
I have checked the thermostat (what a fun job that was to remove) and that works fine in a pan of boiling water. I have replaced the radiator cap. I have replaced the fan belt thinking it may be slipping on the water pump when accelerating). I have jacked the front up and ran for 5/10 mins with teh rad cap off and heater on full.
I diagnosed also that teh the temp sender at the bottom of the radiator was suspect and so diconnected to keep the seconday fan on 100%.
The viscous fan is not seized. On tick over I can stop the fan with a thick piece of cardboard but I would guess if I tried to stop with my hand it would sever my fingers (just a guess but probably not worth putting to the test).
At the time when the temp guage starts to rise I also notice that the heater blows cold air. When temp guage drops back to half way heater seems to function ok (ie blows hot air).
I am still working on the assumption of an air lock. I assumed that 5/10 mins with rad cap off and jacked up would be enough to bleed??.
Please help someone, running out of ideas
J
I have a similar issue to this but my car only seems to try and overheat when sitting in traffic but as soon as i put the heater on the gauge goes back down!
However, it doesnt always overheat in traffic and recently when i had my MOT they had the car running for a good 20 minutes and the fans cut in and temp was fine!!
Am i right in saying i could have a sticking thermostat that isnt always opening when it should and just replace it??
Anybody's help would be appreciated!!
