Engine core plug part numbers
Chris Wilson
I really MUST get the EPC working on either my PC or laptop, but if someone is feeling really kind would they please post up the part numbers for all the core plugs used in the engine block of a 2JZ-GTE please? My local Toyota dealer seems to be having brain fade and has sent out a sump plug and a block water drain plug... :)
Thanks!
  • 2 weeks later...
There's one on the rear - you would normally not see it because the gearbox is obviously mounted there. There are 4 of the larger ones and 2 smaller on the intake side, plus 6 large ones on the exhaust as you said.
Here's some pics from my engine build thread:
You can just about see the hole where the rear one goes in this pic:
