Guest MaTTi Posted October 16, 2008 Share Posted October 16, 2008 My car boost 0.7 bar insted of 1.1 so i want to make my own pressure test on the IC pipings, i will go to a garage and blow air with a gun and listen for air leaks in the system, but which housing should i take off and blow the air in, i have a SARD dump valve. Any pic would be nice as well Quote Link to comment Share on other sites More sharing options...
R Black Posted October 16, 2008 Share Posted October 16, 2008 Good question, interested in the answer to this too, i have a too plugs (one with a valve so you can attach it to a air hose) for my old car Audi S2for just this purpose. Posted via Mobile Device Quote Link to comment Share on other sites More sharing options...
csa Posted October 16, 2008 Share Posted October 16, 2008 i did that using the vacuum hose going to the top of my dump valve. I also connected a boostgauge to check how much pressure I made in the system worked fine, but I was amazed of haw much air it took to go just above 0,1 bar Quote Link to comment Share on other sites More sharing options...
miko_supra Posted October 16, 2008 Share Posted October 16, 2008 i checked my ic hoses a while back and found a small split in one of them. I took the intercooler hose off of the turbo side manifold. Stuck an air pistol in there and sealed it in with insulation tape. 5 minute job and worked a treat. Quote Link to comment Share on other sites More sharing options...
merckx Posted October 16, 2008 Share Posted October 16, 2008 I did mine like this, you can do it at home with a normal tyre inflator. http://www.mkivsupra.net/vbb/showthread.php?t=59939&highlight=tube Quote Link to comment Share on other sites More sharing options...
