problem with new clutch/flywheel
j1mb0b1
hi i have just had a new clutch and flywheel fitted 2 weeks ago and iam getting a scratchy/rattly sound when i pull my clutch up and its doing it when am not moving but when i go to put my clutch back down it goes away. i heard about this before some people have said it's the Clutch release bearing. but dont you get a new one of them when you buy the full clutch and flywheel kit and iam sure it sould last longer than 2 weeks :( any ideas any one ? thanks J...
OEM or aftermarket flywheel?
Aftermarket flywheels generally rattle at idle, it's normal, raising the idle speed slightly should get rid of most of the noise.
The standard OEM flywheel is dual mass which dampens the noise from the gearbox (the rattle you can hear), an OEM flywheel should not rattle at idle.
i did not fit it my self i payed someone but if the Clutch release bearing came with the kit he would have fitted it
The OEM clutch is not sold as a kit, the parts are bought individually. I would check with the garage to see if a new release bearing was fitted. Something is definitely not right, the stock clutch shouldn't rattle.
toyota have agreed to replace my Clutch release bearing for new but i am worried that it may not be the part at fault but maybe a error in fitting as nic says, but the person i have had do the work on the car is very good done work on all my cars at a high level of quality but he has never worked on supras before, Is the clutch and Clutch release bearing a complex job to carry out and could he have done something wrong. i have asked him they question and says he has fitted the parts correctly. does any one have any serjestions? thanks J
just one other thing as well if any one knows, whats the runin mileage for a clutch and Clutch release bearing because iam thinking i did not run it in correctly i drove the steady for around 100 miles then decided to take it to drag strip :D after that this is when i got the problems with Clutch release bearing am i at fault maybe ? :( just fishing around for ideas to why this has happed.. j
Its not a complicated job to change the clutch just a bit of a pita the 1st time. They will be using ramps so even easier.
I would keep quiet and get them to change it and just act supprised if he spots any signs of abuse. I would have thought it would of been upto the job unless your flywheel is knackered. Also find out if they changed the spigot bearing. Its only about £5 so get one fitted if they didnt change that either.
hiya edge and chris i have had a new flywheel to but i dont no about the spigot bearing whats is that and were can i get one from toyota ? with me having all new clutch and flywheel i thoght it would be fine :( iam planning taking the supe to nurburgring next year you think i may have any more probs with it or should it hold out ?
also chris i was speaking to you about a problem i had a few weeks back regarding a loud clanking noise when pulling clutch up and when lifting off thortle i had some one take a look at it for me and they says its the propshaft taking the slack up, says the problem could be in the dif just wear and tear on the diff whats your thorts sould i be worrying is it a cheap fix ?
hiya guys just an update on car the noise i have been getting turns out not to be the Clutch release bearing, but the bush's on the gear linkage have worn and its droped and been catching on the gear box causing the rattling sound, least its not as bad as clutch release bearing :)
