Dann Posted October 15, 2008 Share Posted October 15, 2008 I have just removed my clutch and am now about to re assemble, but those 6 small bolts that hold the clutch on what is the torque setting for them please? Also I had a small fail as I did not expect all the gear box fluid to come gushing out of were the prop shaft goes in, but it did and now am getting some more but were or how do I fill the box do I need one of those pump things ? Many thanks Dann Link to comment Share on other sites More sharing options...
merckx Posted October 15, 2008 Share Posted October 15, 2008 http://www.mkiv.com/manual/manualtt/clutch_replacement/index.html Don't forget when filling the gearbox, do it on level ground and when it's full it will start dripping out of the filler hole. I used a length of polythene tube, a funnel and my iniative. http://www.mkivsupra.net/vbb/showthread.php?t=35935 Link to comment Share on other sites More sharing options...
Dann Posted October 15, 2008 Author Share Posted October 15, 2008 Thanks for the info I am very grateful. It says v160 oil is red well mine that came out was green and stunk of Pee. Also in my book it says w58 oil. I am guessing v160 is the best and better. my car is a 5 speed manual Non turbo. Many thanks Dann Link to comment Share on other sites More sharing options...
bignum Posted October 15, 2008 Share Posted October 15, 2008 I think you can put normal gear oil in the 5 speed,ie, 75/90 Link to comment Share on other sites More sharing options...
Homer Posted October 15, 2008 Share Posted October 15, 2008 I think you can put normal gear oil in the 5 speed,ie, 75/90 Thats correct, just normal 75/90 is whats needed for the 5spd (still bl**dy expensive though!) and smells horrible. Link to comment Share on other sites More sharing options...
Dann Posted October 17, 2008 Author Share Posted October 17, 2008 At last have done it. Many thanks for all your help Dann Link to comment Share on other sites More sharing options...
