sypher_44 Posted October 15, 2008 Share Posted October 15, 2008 (edited) hi i have a tt auto and i think my gearbox is beahaving weird it lockups at 60 kmh as it should but if i press the throttle half the way down its jumping out of lockup and goes upp about 800 rpms.. and when i go back to touching the throttle it makes a like shake and locks the trans again.. should it be like this or is something broken?? and another thing... every time i check my trans fluid it show differnt levels :S and i drive about 2 miles and then stops the car and go trough al the gears and check the stick my english is useles so have patience lol Edited October 15, 2008 by sypher_44 (see edit history) Quote Link to comment Share on other sites More sharing options...
paul mac Posted October 15, 2008 Share Posted October 15, 2008 hi i have a tt auto and i think my gearbox is beahaving weird it lockups at 60 kmh as it should but if i press the throttle half the way down its jumping out of lockup and goes upp about 800 rpms.. and when i go back to touching the throttle it makes a like shake and locks the trans again.. should it be like this or is something broken?? and another thing... every time i check my trans fluid it show differnt levels :S and i drive about 2 miles and then stops the car and go trough al the gears and check the stick my english is useles so have patience lol does sound like a potential fluid level issue, you can check the level cold to the cold level on the dipstick but you also need to check the fluid hot aswell, get the car hot 10 miles down your local motorway should do it, 2 miles would barely have it warm, when hot check the level with the engine idling, also take a note of the colour of the fluid it should be a clear red colour, brown would mean it needs changing Quote Link to comment Share on other sites More sharing options...
sypher_44 Posted October 15, 2008 Author Share Posted October 15, 2008 oops i mean 20 miles... we count in kmh here so i messed the figures up:) the fluid is 1 cm above the max level :S i will dry 2 drain some more and post back Quote Link to comment Share on other sites More sharing options...
robin Posted October 15, 2008 Share Posted October 15, 2008 Before checking the fluid level make sure the car is level and put the box in manual mode and work through all the gears including reverse. Then check. Quote Link to comment Share on other sites More sharing options...
sypher_44 Posted October 16, 2008 Author Share Posted October 16, 2008 when im going through the gears shall i be standing on the brake or should i reverse the car a little and go forward or just plant the foot on the brake??? Quote Link to comment Share on other sites More sharing options...
paul mac Posted October 16, 2008 Share Posted October 16, 2008 when im going through the gears shall i be standing on the brake or should i reverse the car a little and go forward or just plant the foot on the brake??? to check the level there really is no need to put the box through all the gears just check it when hot when its idling in park or neutral Quote Link to comment Share on other sites More sharing options...
jamesmark Posted October 16, 2008 Share Posted October 16, 2008 to check the level there really is no need to put the box through all the gears just check it when hot when its idling in park or neutral Go for a drive warm it up and then check fluid the moment you park up. Quote Link to comment Share on other sites More sharing options...
sypher_44 Posted October 17, 2008 Author Share Posted October 17, 2008 1 1\2 cm above max on hot.... this cant be good Quote Link to comment Share on other sites More sharing options...
