123tom123tom Posted October 13, 2008 Share Posted October 13, 2008 Well am still trying to find a job but in the mean time whilst been bored i thought i would finish some little bits on the supra and post some pics, I know how much people like Pic's on here. I had a sheet of aluminium in the shed so i made that heat sheild for the turbo/surrounding area. A bit make shift but will do the job i think until i get a new job and can buy one lol:p Link to comment Share on other sites More sharing options...
SupraD06 Posted October 13, 2008 Share Posted October 13, 2008 looks good mate, was thingin about making a heat shield for my induction kit but wasnt sure what to put around the edges, is that vacuum hose split and put round the edge? because thats what i was going to use lol Link to comment Share on other sites More sharing options...
mashhead Posted October 13, 2008 Share Posted October 13, 2008 looks good mate, was thingin about making a heat shield for my induction kit but wasnt sure what to put around the edges, is that vacuum hose split and put round the edge? because thats what i was going to use lol Actually its funny you mention that, but I was considering making a box section to go around my induction filter, with a cut out meshed part on the bonnet, to seal upto the box section... Link to comment Share on other sites More sharing options...
SupraD06 Posted October 13, 2008 Share Posted October 13, 2008 not to sure id like to cut a hole in the bonnet myself, might look odd one side and it will soak the air filter aswell Link to comment Share on other sites More sharing options...
supradriver Posted October 13, 2008 Share Posted October 13, 2008 looking good mate Link to comment Share on other sites More sharing options...
Chingy Posted October 13, 2008 Share Posted October 13, 2008 nice Link to comment Share on other sites More sharing options...
123tom123tom Posted October 13, 2008 Author Share Posted October 13, 2008 looks good mate, was thingin about making a heat shield for my induction kit but wasnt sure what to put around the edges, is that vacuum hose split and put round the edge? because thats what i was going to use lol yeah mate it is a bit of vacuum hose want ted to use black but didnt have any, you think it looks ok or should i bin it and save for a proper heat sheild/blanket;) Link to comment Share on other sites More sharing options...
123tom123tom Posted October 13, 2008 Author Share Posted October 13, 2008 nice cheers:) Link to comment Share on other sites More sharing options...
Homer Posted October 13, 2008 Share Posted October 13, 2008 Good going fella, nearly there Couple of things.. If you're not lagging the turbo really consider swapping that plastic breather line for something with better heat resistance. It will get seriously hot and you do not want that thing melting when under high boost (potential engine fire). It's also too high, it needs to be as horizontally as flat as possible or ideally pointing downwards towards the intake/catch can (can't see what you have from the pics) Is that oil feed an XS power one? If so, do NOT use it and ideally, lag the line if you are not using a turbo blanket Is that dump valve *really* secure? If there any flex on it at a standstill thing thing will fly all over the place under high load lift off. If thats an XS power Vband clamp on the turbo/DP then you will need to change it, those things are like toffee and will split as soon as you try to put any real pressure on it. Did you use any XS power gaskets in the hot side? If so expect them to fail very soon, only the exhaust gasket is still holding out on mine, the rest failed badly. Thats all for now, I'm not trying to be a PITA, just wouldn't want to see someone go through all the pain/expence myself (and the new owner) had with the XS kit again. Link to comment Share on other sites More sharing options...
Guest Nizam Posted October 13, 2008 Share Posted October 13, 2008 nice Link to comment Share on other sites More sharing options...
123tom123tom Posted October 13, 2008 Author Share Posted October 13, 2008 Good going fella, nearly there Couple of things.. If you're not lagging the turbo really consider swapping that plastic breather line for something with better heat resistance. It will get seriously hot and you do not want that thing melting when under high boost (potential engine fire). It's also too high, it needs to be as horizontally as flat as possible or ideally pointing downwards towards the intake/catch can (can't see what you have from the pics) Is that oil feed an XS power one? If so, do NOT use it and ideally, lag the line if you are not using a turbo blanket !!!!!!!!!!!!!!no it is a boost logic feed and drain!!!!!!!!!!!!!!!!!!!!!!!!!!!1 Is that dump valve *really* secure? If there any flex on it at a standstill thing thing will fly all over the place under high load lift off. !!!!!!!!!!!!!!!!yes it has a stainless tube that runs up the middle of the silicon!!!!!!!!!!!!!!!!!!!!!!! If thats an XS power Vband clamp on the turbo/DP then you will need to change it, those things are like toffee and will split as soon as you try to put any real pressure on it. !!!!!!!!!!!!!!!!!!!No it isn't got this from powerflow!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! Did you use any XS power gaskets in the hot side? If so expect them to fail very soon, only the exhaust gasket is still holding out on mine, the rest failed badly. !!!!!!!!!!!!!!!!!!!only XS gasket i used was for the downpipe to midpipe joint!!!!!!!!!!!!!!!!!!!!!!!! Thats all for now, I'm not trying to be a PITA, just wouldn't want to see someone go through all the pain/expence myself (and the new owner) had with the XS kit again. and yes it has been a pain in the ass to fit as i knew it would be lol but the result when done with time and care is, I think brilliant for the money. Link to comment Share on other sites More sharing options...
Homer Posted October 13, 2008 Share Posted October 13, 2008 and yes it has been a pain in the ass to fit as i knew it would be lol but the result when done with time and care is, I think brilliant for the money. It was the same for me, the real costs came afterwards Just make sure your injectors and ECU are matched and not a half measure. A stand alone makes things SO much easy and (in the long run) cheaper. BTW, any feedback on the bits above, I didn't type all that out just for amusement Link to comment Share on other sites More sharing options...
SilverSoop Posted October 13, 2008 Share Posted October 13, 2008 It was the same for me, the real costs came afterwards Just make sure your injectors and ECU are matched and not a half measure. A stand alone makes things SO much easy and (in the long run) cheaper. BTW, any feedback on the bits above, I didn't type all that out just for amusement Yes you did... Link to comment Share on other sites More sharing options...
_Shane_ Posted October 13, 2008 Share Posted October 13, 2008 good work bro Link to comment Share on other sites More sharing options...
Homer Posted October 13, 2008 Share Posted October 13, 2008 Yes you did... No, I did not! But just realised Tom replied in the quote (btw you suck at multi-quoting ). All looks good, and nice to see you took all previous suggestions on board Will be interested to see the next (big) step in this build - mapping. Link to comment Share on other sites More sharing options...
SilverSoop Posted October 13, 2008 Share Posted October 13, 2008 No, I did not! But just realised Tom replied in the quote (btw you suck at multi-quoting ). All looks good, and nice to see you took all previous suggestions on board Will be interested to see the next (big) step in this build - mapping. Link to comment Share on other sites More sharing options...
123tom123tom Posted October 14, 2008 Author Share Posted October 14, 2008 it is finding someone in this area who will map it, there doesnt seem to be anyone. Link to comment Share on other sites More sharing options...
