Guest jamesthejames Posted October 13, 2008 Share Posted October 13, 2008 I am installing a remote start/turbo timer in my car...I have dont this many times, but all have used a tach wire signal for letting the module know that its running. This unit requires a signal showing 12 volts when the engine is running. I have already run all the wires to the engine bay, and am wondering if anyone car lead my in the correct direction as to which and were such a wire can be found, please. +12 volt when engine running only. Thank you very much...im so tired of testing for correct wires...some help would be great. Quote Link to comment Share on other sites More sharing options...
dr_jekyll Posted October 13, 2008 Share Posted October 13, 2008 run wire to the igniotion barrel switchable or you can even take an ignition feed fron the back of you radio. Quote Link to comment Share on other sites More sharing options...
Guest jamesthejames Posted October 13, 2008 Share Posted October 13, 2008 ignition feed from said locations would show voltage when the ignition was on, would not mean the engine was actually running Quote Link to comment Share on other sites More sharing options...
dr_jekyll Posted October 13, 2008 Share Posted October 13, 2008 true point . i shall crawl back under my rock Quote Link to comment Share on other sites More sharing options...
Andy Blyth Posted October 13, 2008 Share Posted October 13, 2008 According to Here, you should be able to get an appropriate signal by tapping into the Yellow/Green wire coming from pin 1 (L terminal) of the alternator. Looking at the schematic at the end of the PDF in the linked thread, this signal should be +12V when the alternator is running (i.e. engine is turning at above cranking speed). Hope this helps Quote Link to comment Share on other sites More sharing options...
Guest jamesthejames Posted October 13, 2008 Share Posted October 13, 2008 tyre worx, i appreciate your help, i did not mean to come off as ungrateful, you need not hide under a rock Andy Blyth, thats exactly what I am looking for...but the alternator is almost impossible to get at without removing half the turbo piping and whatnot, do you by chance know where the wire is run in the engine compartment, thanks a lot. Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted October 13, 2008 Share Posted October 13, 2008 If you lift the fuse box cover Toyota have put a 6mm stud terminal marked "Remote start / turbo timer signal pulse". An eyeletted cable for it is in the glove box, with a suitable socket and 1/4 drive ratchet and extension. I know that's what you want to hear, but life can be *hit. Either roll your sleeves up and hack the alternator wiring or throw the damned gimmick in the Gatineau Personally ripping into the engine loom for such a gadget seems criminal... Quote Link to comment Share on other sites More sharing options...
Mike M Posted October 13, 2008 Share Posted October 13, 2008 If you lift the fuse box cover Toyota have put a 6mm stud terminal marked "Remote start / turbo timer signal pulse". An eyeletted cable for it is in the glove box, with a suitable socket and 1/4 drive ratchet and extension. I know that's what you want to hear, but life can be *hit. Either roll your sleeves up and hack the alternator wiring or throw the damned gimmick in the Gatineau Personally ripping into the engine loom for such a gadget seems criminal... :dnow that just cracked me up lol. Quote Link to comment Share on other sites More sharing options...
Guest jamesthejames Posted October 13, 2008 Share Posted October 13, 2008 Chris....you're a funny guy... Quote Link to comment Share on other sites More sharing options...
JustGav Posted October 13, 2008 Share Posted October 13, 2008 You can normally get a harness which is meant for the car. There will more than likely be a pin off the ECU that you can use, however I'm inclined to agree with Chris, more to go wrong Quote Link to comment Share on other sites More sharing options...
