Which rad - Koyo or Fluidyne
Wez
  • Replies 56
As per other thread - I chose Fluidyne and for me it was between the two also after having seen Koyos on other cars. I made this decision based on dusty's opinion that the Fluidyne is the least hassle to fit and slightly better made and I'm not disappointed.
Cheers,
Brian.
My Koyo was a perfect fit no cutting or clearancing but the stock fresh air inlet wont sit on top due to the width of the rad.
I'm sure Thorin fitted the fluidyne and had to cut away some of the fanshround to clear the bottom hose outlet.
Heres a few pics of mine, lovely rad.:)
http://www.mkivsupra.net/vbb/showthread.php?t=144829&highlight=koyo+rad
Edited by Mike M (see edit history)
LeeP fitted my fluidyne today and the stock fan shroud does need a tiny bit of trimming to clear the bottom hose outlet, also the top hose outlet is slightly nearer the center of the car than the stock one meaning my hard top hose dont fit quite as well now and is buldging the silicon pipe a tad (you can just make it out in the pic) Lee is going to sort this when the car goes in for its winter makeover.
So all in the fluidyne is not a direct fit but it is very close.
http://i30.photobucket.com/albums/c338/jamie450x/018.jpg
That was exactly my experience too, info and photo's at http://www.mkivsupra.net/vbb/showthread.php?t=83646
I keep reading people saying "yeah the fluidyne is completely as stock fitment". I can only assume they didn't actually fit it themselves. It's fine though and I'm happy with it.
I know the PWR can be a bit of a *astard to fit, due to it being quite a bit larger I believe.
If Rob says the Koyo is a perfect fit then I'd believe him, if he's lying I'll hunt him down and kill him.
Thats looking fine now mate, nice and tidy!:cool:
Easier to maintain than a chrome engine bay too, less time polishing, more time driving!
p.s wheres the polished power steering reservoir!?
If you had choice between Koyo and Fluidyne which would you choose and why.
Neither, I'd personally fit a Power Enterprise radiator. I use to have a Fluidyne rad fitted, it coped with everyday driving okay, but when really pushing it on a hot day or on track (drifting), temps started to rise.
I swamped to a PE rad and this coped much better in all conditions, fit and finish was also better than the Fluidyne. Quite a bit more expensive though.
http://img181.imageshack.us/img181/5938/1jza80powerenterpriseranf8.jpg http://img213.imageshack.us/img213/3220/2jza80powerenterpriserauq4.jpg
I have had both , only one problem with the Fluidyne, is that you have to use the rad cap provided with it . You cant use a stock cap with this unit. The koyo uses a supra Mk3 fitment , so you can change between the caps on pressure. Also the koyo is thicker. I have had mine for the past 3 years and run a 1.1bar cap. Its fits perfect and the twin fans do a great job on it . The water temps are usually around 80 degrees, i also run a trd thermo aswell 79 degrees .
