Guest bmx Posted October 11, 2008 Share Posted October 11, 2008 hi people dont really post on the forum but i have a brake question. i've jst brought sum front disks and pads off some one on here and after fitting them and bleeding the brakes, took it for a drive and under braking, bad judder/pulsing through the brake pedal, not quite sure wot it could be as it all looks fine to me. everything went back on fine too. Quote Link to comment Share on other sites More sharing options...
Wez Posted October 11, 2008 Share Posted October 11, 2008 Were they new or used? Quote Link to comment Share on other sites More sharing options...
Guest Garfy Posted October 11, 2008 Share Posted October 11, 2008 sounds like warped disc's to me Quote Link to comment Share on other sites More sharing options...
Guest bmx Posted October 11, 2008 Share Posted October 11, 2008 used mate but near enough new pads and disks. just had the car jacked up and the wheels spin normal just catch the pads slightly which is normal. Quote Link to comment Share on other sites More sharing options...
Guest WDFL12 Posted October 11, 2008 Share Posted October 11, 2008 Hi Mate be absolutely sure that the hub face , is clean and the inside face of the disc ? short of that are there no visible high spots on the disc ? If all this is ok then its got to be the Disc,s warped ! Hope that helps . Quote Link to comment Share on other sites More sharing options...
Guest bmx Posted October 13, 2008 Share Posted October 13, 2008 no visable high spots on the disk and ive stripped them down and 1 of the slider pins was siezed so i swapped the caliper cage for another 1 which has 2 pins that are fine, test drive and its 60% better. Quote Link to comment Share on other sites More sharing options...
