Road legal race car
Steve Sherwood
  • Replies 135
Every time i see this it motivates me to spend a fortune on my car.
Please can you change this pipe, it look horrible.
http://www.mkivsupra.net/vbb/attachment.php?attachmentid=91268&d=1240256103
Jon
No you can't get ready made bends that shape the only way to do it is cut lots of segments and tig them. Its the best we can do in our home workshop, getting a compmny to make a custom pipe costs too much, just need to get if finished. Will need to do some refinshing jobs over next winter when we have time.
  • 1 month later...
At last got alloy tanks made power steering oil, catch tank and expansion tank. all fuel and oil lines made up and clipped up. Carbon bonnet and rear hatch fitted, tyres fitted to road wheels 355/25/19 rear and 265/30/19 front.
Thanks to Ryan for supplying and fitting Solaris ECU and getting the motor running.
Thanks Jamie looks very different with road wheels and lowered.
Its had to visualise it with all the panels on and painted but I think it should work.
The Orange with Black wheels work great, what width are them rear wheels?, 13"?
  • 1 month later...
Almost ready to test on a track mapped for road fuel made 700 hp @ the hubs on Bp Ultimate @ 1.5 bar using AET Turbos dyna pack. Coservative map Ryan could have got a little more but best to be safe and 700 is more than enough for road/trac day use. Got the basic race map done had some problems with nitrous need to take advice before using it as it can be very distructive if not spot on.
Made 800 hp @ hubs on zero oxygen fuel. One intresting point is that we are using HKS 264 VVTi inlet cam and 272 exhaust as HKS recommeded. This combination works well at low boost but as boost goes up does not work well. AET recommend use of an exhaust cam with the same duration as inlet or less at high boost. Reduce overlap and increase lift so will change to Crower 264 exhaust as it has higher lift than HKS 264 exhaust cam.
That with high oxygen fuel could give another 100 hp on the turbo.
The car will still need a lot of setting up before we get the best from it.
