NA-T emanage blue base map
Supradaz
Can anyone provide me with a NA-T emanage blue base map.
Just need to get the car running until I get the map sensor harness installed.
I'm in N.Irleand and I need to find someone here who can do a proper ECU map in due course. Running out of funds so I might have to wait a while for that and just need to get the car driving and back to my own garage.
I bought the N/A T kit of Knightrider and it is running on 440 injectors. De-cat pipe and full stainless exhaust.
50mm waste gate with screamer pipe and down pipe, FPR, BOV etc.
I can provide more info on spec as I'm not sure what info is relevant. I will pass on any info to my friend who is doing the install for me as most of this goes way over my head. I just like to drive Supra's LOL.
Any relevant N/A T base maps would be great.
thanks
i thaught the emanage being a piggy back unit used the original ecus base map and alowed you to alter it to acount for the boost and fueling , i may be wrong as i am far from an expert. but i am in the process of a similar setup and i am curently using the car and its running fine aslong as i saty away from the boost until i get a new ecu , or piggy back unit in .so if i find anything out ill let you know
