has anybody ever used avoltage clamp
dr_jekyll
I was wondering if anybody had ever used a voltage clamp on the map sensor to stop it from bringing up an error code , i have a na/t and i have been told that i need to set a voltage clamp on my map sensor , but in all honesty iv , no i dea what a volt clamp is or what i need to clamp the voltage at , , so any help would be great
Edited by dr_jekyll (see edit history)
If you by an emanage, this feature is included;)
its na so when would it exactly ever see boost? the stock map wont read much above a couple of psi so why would you continue trying to make it do so when its only going to keep cutting fuel?
ihave tried to run a tt map sensor , but the lower voltage it gives to the ecu via the signal wire means the car runs lean so i tried upping the voltage down that signal wire by ruducing a 12v feed to 2.4v witch is what the na map sensor gives and i thaught then i could mariginly adjust that signa + or - using my apexi safc but to no avail.
after that i replaced the tt map sensor with the ge map sensor so the car wa fueling correctly pre boost and fitted a one way valve on the vacume line witch did allw me to boost until i lifted off the throttle and the car flat out stalled at 50mph, not good ,
in regardes to the question , wher am i geting the information to try these thing , well, i just thaught i use a bit of initiative and try these thing before i asked for advice .
NA/T conversions have been discussed on here many times before and there NO NOs, ok methods and then the proper way to do things.
At the moment I feel you are doing some NO NOs.
Changing the map sensors wouldnt work as the scalings are different and you have no way of changing that within the stock ECU. It wouldnt help if you could as I very much doubt the stock NA ECU has any fuel or ignition maps for postive pressure anyway.
There are plenty of cheapish AEM standalones for sale on here at the moment, if you have a 6 speed maybe you should look at one of these and do it properly before you kill your motor.
All my opinion of course :thumbs:
He`s na/t, does this make any difference, i was refering to a tt map setup so may be different,:search:
yeah being na-t makes a diff as the na map only reads to 2 or 3 psi before cutting fuel. As said above the best way of dealing with it is standalone but i've heard of lots of people in the US having sucess in using check valves so that when off boost (mani vacuum) the engine runs like normal or as close as it can, then when it comes on boost the check valve isolates the map and the ecu believes its at WOT(ambient pressure or slightly over), after that you use something like mapECU to tune fuel for boost with its internal 35psi map sensor.
