SupraShaun Posted October 9, 2008 Share Posted October 9, 2008 Hi all, can someone do me a favour and post up an image of the rear suspension set up from an EPC? I have one from a service manual but isnt very detailed. The reason I ask is the car has just failed the MOT on: "Offside inner rear radius arm has excessive play in the pin/bush" After some searching im hoping that this isnt the bit where you have to replace the whole thing thanks all Shaun Quote Link to comment Share on other sites More sharing options...
Nic Posted October 9, 2008 Share Posted October 9, 2008 http://img378.imageshack.us/img378/3857/rearsuspensionepceb8.jpg Quote Link to comment Share on other sites More sharing options...
SupraShaun Posted October 9, 2008 Author Share Posted October 9, 2008 Cheers Nic Quote Link to comment Share on other sites More sharing options...
Supradk84 Posted October 9, 2008 Share Posted October 9, 2008 (edited) To late Edited October 9, 2008 by Supradk84 to slow (see edit history) Quote Link to comment Share on other sites More sharing options...
SupraShaun Posted October 9, 2008 Author Share Posted October 9, 2008 Im guessing its the bit(s) I have circled, if that's the case can these bushes be replaced? Quote Link to comment Share on other sites More sharing options...
miko_supra Posted October 9, 2008 Share Posted October 9, 2008 Im guessing its the bit(s) I have circled, if that's the case can these bushes be replaced? Toyota only supply replacement arms rather than the individual bushes, if you want this then contact nic for some good prices. If you just want to replace the bushes then you can buy after market poly bushes. I can remove and fit these if needed. Quote Link to comment Share on other sites More sharing options...
SupraShaun Posted October 9, 2008 Author Share Posted October 9, 2008 Toyota only supply replacement arms rather than the individual bushes, if you want this then contact nic for some good prices. If you just want to replace the bushes then you can buy after market poly bushes. I can remove and fit these if needed. I would rather look at replacing the bushes than the whole arm. From here: http://www.powerflex.co.uk/products.asp?cat=0033&catalog=0433&submit1.x=12&submit1.y=17&submit1=GO would it be part number PFR76-609 that i need? Also what's your turnaround time? I have ten days otherwise i have to pay for a retest. Ill get the wheel of etc tomorrow to check its the right bit that im looking at. Quote Link to comment Share on other sites More sharing options...
Nic Posted October 9, 2008 Share Posted October 9, 2008 If you're going to replace the bushes, I would do both sides at the same time. Quote Link to comment Share on other sites More sharing options...
miko_supra Posted October 9, 2008 Share Posted October 9, 2008 I would rather look at replacing the bushes than the whole arm. From here: http://www.powerflex.co.uk/products.asp?cat=0033&catalog=0433&submit1.x=12&submit1.y=17&submit1=GO would it be part number PFR76-609 that i need? Also what's your turnaround time? I have ten days otherwise i have to pay for a retest. Ill get the wheel of etc tomorrow to check its the right bit that im looking at. Im not sure, I dont usually deal with powerflex and everyone always uses different terminology. Your best contacting them in case. It would probably only take me an hour or so to do it so it's just up to the postman really for when i can get it back to you by. Quote Link to comment Share on other sites More sharing options...
miko_supra Posted October 9, 2008 Share Posted October 9, 2008 SupraShaun you have PM Quote Link to comment Share on other sites More sharing options...
SupraShaun Posted October 9, 2008 Author Share Posted October 9, 2008 SupraShaun you have PM Replied Quote Link to comment Share on other sites More sharing options...
