Removing cig lighter and dash dimmer
Rob Dublin
Might be wrong, But on the dimmer i belive the nob part pops off and the rest will come away. The cig lighter need the small flaps pushed in and it will then drop out. You can see a flap on the cig lighter pic you uploaded. Hope thats of some help....
Will try and upload a pic, Prob won't work...
Edited by Missile (see edit history)
Might be wrong, But on the dimmer i belive the nob part pops off and the will come away. The cig lighter need the small flaps pushed in and it then drop out. You can see a flap on the cig lighter pic. Hope thats of some help....
:yeahthat:
Once you remove the dimmer knob there will be a nut holding the dimmer in place.
The cig lighter pushes out from the back of the dash panel
I found the cig lighter a real git to remove. Yes, it has tabs of sorts, but I don't think they're designed to ever be used by anything bigger than microscopic fingers. I had to use matchsticks to jam them in, and it took AGES.
I'll get some tinnies in for the night so.
