rick001 Posted October 7, 2008 Share Posted October 7, 2008 I recently replaced my j-spec front brake set up for the uk jobby as my jap ones were juddering badly after 2 sets (1 second hand and 1 a blue print) and now im sure i can feel the UKs starting to very slightly judder could my front wheel alignment be causing this? Quote Link to comment Share on other sites More sharing options...
Nic Posted October 7, 2008 Share Posted October 7, 2008 A knackered wheel bearing can cause juddering under braking. Is it juddering on one side? Is it the near side (passenger side)? Quote Link to comment Share on other sites More sharing options...
rick001 Posted October 7, 2008 Author Share Posted October 7, 2008 Hi nic, im reluctant to think so as i changed it last year - i have no uneven wear on my front tyres either! Quote Link to comment Share on other sites More sharing options...
AlanM Posted October 7, 2008 Share Posted October 7, 2008 My Toyota UK Spec disks warped within a few hundred miles with no fierce stopping having taken place. The blueprint ones I replaced them wioth are fine Quote Link to comment Share on other sites More sharing options...
rick001 Posted October 7, 2008 Author Share Posted October 7, 2008 My Toyota UK Spec disks warped within a few hundred miles with no fierce stopping having taken place. The blueprint ones I replaced them wioth are fine Do you think there was a route cause for this Alan such as poor manufacture or just unknown? Its really annoying when you spend all the money on OEM stuff and its gives out in quick time Quote Link to comment Share on other sites More sharing options...
JODY T Posted October 7, 2008 Share Posted October 7, 2008 This happened to me with Toyota ones, I put blue print ones on also... Or you ould get your toyota ones faced true again... If they have already warped its unlikely they will again.. Quote Link to comment Share on other sites More sharing options...
AlanM Posted October 7, 2008 Share Posted October 7, 2008 Do you think there was a route cause for this Alan such as poor manufacture or just unknown? Its really annoying when you spend all the money on OEM stuff and its gives out in quick time No idea, except it was not as a result of vigourous use. They were badly warped, Jody can vouch for this he had them lying about for a while at Interpro where the blueprints went on. No trouble with them - and they have been used enthusiastically a few times Quote Link to comment Share on other sites More sharing options...
rick001 Posted October 7, 2008 Author Share Posted October 7, 2008 Thanks guys Quote Link to comment Share on other sites More sharing options...
Thorin Posted October 7, 2008 Share Posted October 7, 2008 What pads? Poor pad choice (especially if people insist on using incendiary devices like the ones made by EBC) can leave material build up on the discs. Quote Link to comment Share on other sites More sharing options...
AlanM Posted October 7, 2008 Share Posted October 7, 2008 I had Toyota pads n mine Quote Link to comment Share on other sites More sharing options...
rick001 Posted October 7, 2008 Author Share Posted October 7, 2008 i have genuine Toyota too Quote Link to comment Share on other sites More sharing options...
Thorin Posted October 7, 2008 Share Posted October 7, 2008 Should be ok then, calliper sticking and overheating the discs? Quote Link to comment Share on other sites More sharing options...
rick001 Posted October 7, 2008 Author Share Posted October 7, 2008 Should be ok then, calliper sticking and overheating the discs? Hope this would not be the case as there brand spanking but worth a check Quote Link to comment Share on other sites More sharing options...
bignum Posted October 7, 2008 Share Posted October 7, 2008 Have you done any heavy braking then sat with your foot on the brake pedal, i.e come down a m/way slip road to traffic lights? Quote Link to comment Share on other sites More sharing options...
bigbloodyturbo Posted October 7, 2008 Share Posted October 7, 2008 did you bed them properly, not just do the usual drive easy for 300 miles. Quote Link to comment Share on other sites More sharing options...
dan4 Posted October 7, 2008 Share Posted October 7, 2008 i find they warp easily, then i skim them and it never happens again. The heat cycle maybe strengthens them Is there any corrosion behind the disc causing it to sit pissed? Quote Link to comment Share on other sites More sharing options...
