supra_si Posted October 6, 2008 Share Posted October 6, 2008 Basically guys my new rad should arrive tomorrow and i need it on asap, Is it a fairly straight forward DIY Job or should i get a qualified mechanic to do it and pay him for the privilege. Ive had a look on a fitting guide and ive seen one that has given me the faith to have a go but i dont wanna fudge it up. Quote Link to comment Share on other sites More sharing options...
heckler Posted October 6, 2008 Share Posted October 6, 2008 it very easy, but you will need to get some 4life red coolant too - changed mine in about 20 mins Quote Link to comment Share on other sites More sharing options...
supra_si Posted October 6, 2008 Author Share Posted October 6, 2008 20 mins well theres no cat in hells chance of me beating that, i think i may have the fan shroud off in 20 mins lol How much is toy 4 life coolant? Quote Link to comment Share on other sites More sharing options...
heckler Posted October 6, 2008 Share Posted October 6, 2008 20 mins well theres no cat in hells chance of me beating that, i think i may have the fan shroud off in 20 mins lol How much is toy 4 life coolant? erm... about £17 for 5 ltrs i think (on the last check) Quote Link to comment Share on other sites More sharing options...
supra_si Posted October 6, 2008 Author Share Posted October 6, 2008 ok thanks and i need 10 ltrs dont I? Quote Link to comment Share on other sites More sharing options...
heckler Posted October 6, 2008 Share Posted October 6, 2008 ok thanks and i need 10 ltrs dont I? think so.... but that only if you drain the whole system, i didnt, only the radiator - I bunged up the lower rad pipe Quote Link to comment Share on other sites More sharing options...
supra_si Posted October 6, 2008 Author Share Posted October 6, 2008 yeh i think il drain the full lot into a bucket. I guess the cost of the coolant would be the cost of getting a mechanic/mate to do it for me so a little saving and i get to be hands on with the car at last. Quote Link to comment Share on other sites More sharing options...
heckler Posted October 6, 2008 Share Posted October 6, 2008 yeh i think il drain the full lot into a bucket. I guess the cost of the coolant would be the cost of getting a mechanic/mate to do it for me so a little saving and i get to be hands on with the car at last. Thats what I said to myself about my single conversion. saved myself who knows how much in labour, and i reckon i did it faster too - 14 hrs . I kept the tea/food breaks to a minimum i.e. none! Quote Link to comment Share on other sites More sharing options...
supra_si Posted October 6, 2008 Author Share Posted October 6, 2008 well im in work now so as soon as i get back its quick shower phone to mr T for coolant then fingers crossed il get back b4 the rad is delivered, if i can do this in under 2 hours il be impressed with myself, im no mechanic so no single conversion just yet Quote Link to comment Share on other sites More sharing options...
Kirk Posted October 6, 2008 Share Posted October 6, 2008 Draining the entire system is worth it, just find all the draining nipples on the block,rad etc! I can't say I've used the 4 life coolant, is it premixed with distilled water already?? Posted via Mobile Device Quote Link to comment Share on other sites More sharing options...
heckler Posted October 6, 2008 Share Posted October 6, 2008 well im in work now so as soon as i get back its quick shower phone to mr T for coolant then fingers crossed il get back b4 the rad is delivered, if i can do this in under 2 hours il be impressed with myself, im no mechanic so no single conversion just yet just make sure you get the right rad, as theres 2 Quote Link to comment Share on other sites More sharing options...
heckler Posted October 6, 2008 Share Posted October 6, 2008 Draining the entire system is worth it, just find all the draining nipples on the block,rad etc! I can't say I've used the 4 life coolant, is it premixed with distilled water already?? Posted via Mobile Device yup, comes pre mix Quote Link to comment Share on other sites More sharing options...
Homer Posted October 6, 2008 Share Posted October 6, 2008 It's a easy 30 minute job even for an amatuer, you'll be fine Don't bother with Toyota4life, just get a basic glycol based antifreeze and use that, it's a fraction of the cost and does the same job. Quote Link to comment Share on other sites More sharing options...
supra_si Posted October 6, 2008 Author Share Posted October 6, 2008 im getting a direct replacement specifically for an auto box so fingers crossed it will be a straight swap. if not il be in tears Quote Link to comment Share on other sites More sharing options...
supra_si Posted October 6, 2008 Author Share Posted October 6, 2008 any suggestions homer? and mix ratios Quote Link to comment Share on other sites More sharing options...
Homer Posted October 6, 2008 Share Posted October 6, 2008 any suggestions homer? and mix ratios Halfords/motor factors glycol based coolant, it's normally ready mixed. It's about £4 for 5 litres instead of £15 from Toyota. Quote Link to comment Share on other sites More sharing options...
Homer Posted October 6, 2008 Share Posted October 6, 2008 im getting a direct replacement specifically for an auto box so fingers crossed it will be a straight swap. if not il be in tears Bit more tricky on the auto as you have the oil cooler to sort out. Make sure you top up the box oil afterwards. Quote Link to comment Share on other sites More sharing options...
supra_si Posted October 6, 2008 Author Share Posted October 6, 2008 What kinda oil are we on about here? I was hoping you would say halfords coolant as its about 15 miles closer than my nearest mrT Quote Link to comment Share on other sites More sharing options...
Homer Posted October 6, 2008 Share Posted October 6, 2008 What kinda oil are we on about here? Dexron III ATF Quote Link to comment Share on other sites More sharing options...
supra_si Posted October 7, 2008 Author Share Posted October 7, 2008 Ahh right, i dont have any of that, Il have a look for some at halfords Quote Link to comment Share on other sites More sharing options...
Thorin Posted October 7, 2008 Share Posted October 7, 2008 Easy job. There's a very helpful thread here which should be added to the Technical Reference section IMO http://www.mkivsupra.net/vbb/showthread.php?t=83646 Took me a fair bit longer than half an hour, but would certainly take a lot less if I were to do it again. Quote Link to comment Share on other sites More sharing options...
supra_si Posted October 7, 2008 Author Share Posted October 7, 2008 aii thats the method i think im gonna use too, thanks for the linky thorin, just gotta wait for the missus to move her car so i can get on the drive. although its raining now gggrrrr. i think im gonn just do it in the rain as i need it done asap Quote Link to comment Share on other sites More sharing options...
supra_si Posted October 7, 2008 Author Share Posted October 7, 2008 just a cpl of pics as its arrived just moments ago. now the hole above the drain tap i gather is for the water temp sensor, anyone know what the L shaped bar is near the bottom hose pipe? Quote Link to comment Share on other sites More sharing options...
Dazzi Posted October 7, 2008 Share Posted October 7, 2008 I had this L shaped part on mine. It was blocked off... Quote Link to comment Share on other sites More sharing options...
supra_si Posted October 7, 2008 Author Share Posted October 7, 2008 where does the auto transmission oil go like? Quote Link to comment Share on other sites More sharing options...
