SupraD06 Posted October 6, 2008 Share Posted October 6, 2008 Hiya guys, ive just been out in the supra and as ive just reversed up our drive ( quite a slope ) i could hear a wierd sound coming from the passanger side wheel sort of area, it sounds like its either rubbing or somthing, and then once i was on the flat i didnt notice it as much, almost like it only did it when its under load or more stress to move, could this be a bearing or something? I had all new suspension on the car less than 800miles ago so dont think its suspension related, and only had an M.O.T done a few weeks back, also not sure if its the same noise but when im just driving at around 30mph if i have my window down and dont excelerate i can hear a ticking noise like once per full wheel rotation. Could this be the same problem. Quote Link to comment Share on other sites More sharing options...
Guest Garfy Posted October 7, 2008 Share Posted October 7, 2008 what sort of noise is it? metal? Rubber? Quote Link to comment Share on other sites More sharing options...
bodilx6 Posted October 7, 2008 Share Posted October 7, 2008 Do you have a lowered suspension? If I were you, I would jack the car up, remove the wheel and have a good look in the wheel arch to see if there are any marks of rubbing. It could be the inner fender, as that can give some scary noises if its rubbing, but that would usually be while turning. Quote Link to comment Share on other sites More sharing options...
