Guest markel Posted October 6, 2008 Share Posted October 6, 2008 Hi i have my drag car for sale! This is a massive spec drag Supra. All the results are only on concrete tracks NO glue ! Selling because of a bad financial situation and i want to build a tubeframed Pro Stock car with the same spec 2JZ! DRAG Supra Best ¼ mile ET 9.3sek (poor track conditions, 2.0bar boost) Best ¼ mile trapspeed 248kph Best 60ft 1.38sec Car weight 1250kg Power 1200hp / TQ 1200Nm, 1000+hp and NM at 6150-9500rpm Fuel VP Racing C16 Tuned on engine dyno to 9500rpm/ 2.8bar boost (VM Performance AB, Sweden) Car built and serviced at Esracing, Estonia. http://www.es-racing.ee Car is in premium condition and ready to race Additional specs, information and dyno graphs on demand Car can go consistantly 8sek runs on good drag strips only if you are quick enough to change the gears correctly Drivetrain: Getrag V160 6-spd gearbox - new syncros! TRD gearbox mounts RPS Carbon/Carbon clutch RPS flywheel – drag spec Driveshaftshop CrMo driveshaft TRD LSD differential Rear axle and diff solid mounts Weld Magnum gold 15inch dragwheels 10 inch wide Weld Magnum gold front runners Custom Alu wheel adapters Long racing wheelstuds Engine: 2JZ inline 6 CP pistons Carillo H-beam rods ACL/Calico coated bearings Titan billet main caps L19 headstuds ARP mainstuds Ferrea full +1mm valvetrain (inc. bronze guides, locks, double springs) 272/272 JUN cams with 10.8mm lift Shim under bucket conversion HKS cam gears VirtualWorks intake manifold 100mm VirtualWorks throttle body FullRace exhaust manifold Moroso dry sump oil pan Moroso 4stage dry sump Drag spec oil pump Pace Motorsport oil tank BoostLogic SFI spec front damper Meziere electric water pump Unorthodox pulleys Fluidyne radiator 2xFlexALite electric fans Custom intercooler and piping with safety clamps 2x Tial 44 wastegate 2xBlitz blow off valve Garrett GT4508R ball-bearing turbocharger 5“ SS downpipe AN type race connectors/SS braided hoses (oil and fuel) Custom crankcase ventilation Electronics: Autronic SM4 EMS Autronic R500 CDI ignition 2x Autronic boost solenoids EGT, fuel press, oil press datalogging B&M line lock system Oil temp gauge Autometer tacho 10000rpm with shiftlight Fuel: 3xBosch 044 pumps Custom billet fuel blocks(terminals) 6x1600cc injectors Titan Motorsports fuelrail Aeromotive high flow FPR Pressure gauge JAZ safety gas tank in the trunk – in the isolated alu box Racing braided all fuel lines Body and suspension: 1250kg Supra MKIV hardtop (without driver) 8,5 sec 8-point rollcage, meets FIA standards solid engine mounts Sparco EVO 2 FIA-homologated seat TRD widebody rear AbFlug Aero glass fibre bonnet AbFlug front bumper Dzus quick release Simpson braking chute – manual release Glass fibre rear hatch 7kg Glass fibre doors with carbon inside panels 5kg /pc Custom ram air intake through headlight Double adjustable drag Strange rear coilovers – pneumo control for rebound from Sm4 HKS front coilovers Custom carbon fibre dashboard Lexan-windows (windshield original) electric kill switches (outer and inner) RJS safety window net Lightweight dragrace steering rack and column (custom mounts and uniball rodends) Moroso Quick release steering wheel adaptor AbFlug steering wheel As we have no good tracks in Estonia, this car should find a new home where there are glued track and someone can show the true potential of this beast. I have driven it only 1 season - 60 starts !!! Can make a rebuild with new bearings or give evrything needed for a rebuild with the car! Invested more than 60K £ pics can be found : http://suchen.mobile.de/fahrzeuge/details.html?id=76423171 For sale 41 000€ Markel markel [at] baltifiltrid.ee +372 521 5678 Link to comment Share on other sites More sharing options...
Sean1933 Posted October 6, 2008 Share Posted October 6, 2008 Now thats a spec list, awesome machine. Good luck with the sale mate. Link to comment Share on other sites More sharing options...
Gazboy Posted October 6, 2008 Share Posted October 6, 2008 Holy hell that's lighter than the carbon supra in Scandinavia Link to comment Share on other sites More sharing options...
Guest markel Posted October 7, 2008 Share Posted October 7, 2008 Do you happen to know who is the owner of a carbon supra? Link to comment Share on other sites More sharing options...
Dave17 Posted October 7, 2008 Share Posted October 7, 2008 I want! Link to comment Share on other sites More sharing options...
StuartW Posted October 17, 2008 Share Posted October 17, 2008 I am not interested in buying this as i am currently building my own "Ultimate Street Drag Supra" (See link in my sig) But i am Very interested in it being bought into the uk where it could hopefully achieve better et's;) I am sure we would all like to see more pics and it will help with the sale. Cheers Stuart Link to comment Share on other sites More sharing options...
Rich Posted October 17, 2008 Share Posted October 17, 2008 nice spec! Link to comment Share on other sites More sharing options...
bolarbag Posted October 17, 2008 Share Posted October 17, 2008 Wow - and again Wow! :cool: Link to comment Share on other sites More sharing options...
Chingy Posted October 17, 2008 Share Posted October 17, 2008 awesome, good luck with the sale Link to comment Share on other sites More sharing options...
StuartW Posted November 3, 2008 Share Posted November 3, 2008 I have been talking lots with Markel through pm's picking his brains for my build and he is Very Knowledgeable. Bump For Markel! It would be awesome to see this run over here with a new enthusiastic owner Markel...Can you post anymore pictures or maybe a Youtube Video? Link to comment Share on other sites More sharing options...
StuartW Posted November 3, 2008 Share Posted November 3, 2008 Hows about these thrown in with the sale?? Link to comment Share on other sites More sharing options...
mr lover Posted November 3, 2008 Share Posted November 3, 2008 Hows about these thrown in with the sale?? will I need a restrictor ring Link to comment Share on other sites More sharing options...
Pig Posted November 3, 2008 Share Posted November 3, 2008 Wow, amazing spec! Good luck with the sale! Link to comment Share on other sites More sharing options...
vvteye Posted November 3, 2008 Share Posted November 3, 2008 I'd be happy if I could just afford the wheels Love to see it over here... Where's JamieP when you need him Link to comment Share on other sites More sharing options...
Kranz Posted November 3, 2008 Share Posted November 3, 2008 Hows about these thrown in with the sale?? Love the sign in the background of the second pic Great car, now I need to win the lottery Link to comment Share on other sites More sharing options...
vase Posted November 9, 2008 Share Posted November 9, 2008 Hows about these thrown in with the sale?? Just go to Estonia. All the girls look like that over there. Awesome machine you got there buddy. Good luck with the sale! Link to comment Share on other sites More sharing options...
gaz1 Posted November 9, 2008 Share Posted November 9, 2008 wow awesome spec:d Link to comment Share on other sites More sharing options...
Supe Posted November 9, 2008 Share Posted November 9, 2008 Very Good luck with sale Link to comment Share on other sites More sharing options...
Guest markel Posted November 10, 2008 Share Posted November 10, 2008 Hi , these girls are Latvian , but they look ok to me also if anyone has not understood - they are not wearing bra here are some links of the car in action: http://www.youtube.com/watch?v=yC4yvUKtDd0 Last one is the 9.3 run with 248kmh trap speed. A small wheelie Thanks for the bumps! Someone buy this beast- so i can build a 2jz monster Markel Link to comment Share on other sites More sharing options...
fastisnice Posted November 12, 2008 Share Posted November 12, 2008 Wow to the spec, well done for an amazing car! Tallinn=amazing city and the best girls Link to comment Share on other sites More sharing options...
StuartW Posted December 19, 2009 Share Posted December 19, 2009 Markel! Did you ever sell the white car? Did the new Drag project take off? Link to comment Share on other sites More sharing options...
