1200HP Drag Supra Single Turbo 6spd
Guest markel
Guest markel
Hi
i have my drag car for sale! This is a massive spec drag Supra.
All the results are only on concrete tracks NO glue ! Selling because of a bad financial situation and i want to build a tubeframed Pro Stock car with the same spec 2JZ!
DRAG Supra
Best ¼ mile ET 9.3sek (poor track conditions, 2.0bar boost)
Best ¼ mile trapspeed 248kph
Best 60ft 1.38sec
Car weight 1250kg
Power 1200hp / TQ 1200Nm, 1000+hp and NM at 6150-9500rpm
Fuel VP Racing C16
Tuned on engine dyno to 9500rpm/ 2.8bar boost (VM Performance AB, Sweden)
Car built and serviced at Esracing, Estonia. http://www.es-racing.ee
Car is in premium condition and ready to race
Additional specs, information and dyno graphs on demand
Car can go consistantly 8sek runs on good drag strips only if you are quick enough to change the gears correctly :)
Drivetrain:
Getrag V160 6-spd gearbox - new syncros!
TRD gearbox mounts
RPS Carbon/Carbon clutch
RPS flywheel – drag spec
Driveshaftshop CrMo driveshaft
TRD LSD differential
Rear axle and diff solid mounts
Weld Magnum gold 15inch dragwheels 10 inch wide
Weld Magnum gold front runners
Custom Alu wheel adapters
Long racing wheelstuds
Engine:
2JZ inline 6
CP pistons
Carillo H-beam rods
ACL/Calico coated bearings
Titan billet main caps
L19 headstuds
ARP mainstuds
Ferrea full +1mm valvetrain (inc. bronze guides, locks, double springs)
272/272 JUN cams with 10.8mm lift
Shim under bucket conversion
HKS cam gears
VirtualWorks intake manifold
100mm VirtualWorks throttle body
FullRace exhaust manifold
Moroso dry sump oil pan
Moroso 4stage dry sump Drag spec oil pump
Pace Motorsport oil tank
BoostLogic SFI spec front damper
Meziere electric water pump
Unorthodox pulleys
Fluidyne radiator
2xFlexALite electric fans
Custom intercooler and piping with safety clamps
2x Tial 44 wastegate
2xBlitz blow off valve
Garrett GT4508R ball-bearing turbocharger
5“ SS downpipe
AN type race connectors/SS braided hoses (oil and fuel)
Custom crankcase ventilation
Electronics:
Autronic SM4 EMS
Autronic R500 CDI ignition
2x Autronic boost solenoids
EGT, fuel press, oil press datalogging
B&M line lock system
Oil temp gauge
Autometer tacho 10000rpm with shiftlight
Fuel:
3xBosch 044 pumps
Custom billet fuel blocks(terminals)
6x1600cc injectors
Titan Motorsports fuelrail
Aeromotive high flow FPR
Pressure gauge
JAZ safety gas tank in the trunk – in the isolated alu box
Racing braided all fuel lines
Body and suspension:
1250kg Supra MKIV hardtop (without driver)
8,5 sec 8-point rollcage, meets FIA standards
solid engine mounts
Sparco EVO 2 FIA-homologated seat
TRD widebody rear
AbFlug Aero glass fibre bonnet
AbFlug front bumper Dzus quick release
Simpson braking chute – manual release
Glass fibre rear hatch 7kg
Glass fibre doors with carbon inside panels 5kg /pc
Custom ram air intake through headlight
Double adjustable drag Strange rear coilovers – pneumo control for rebound from Sm4
HKS front coilovers
Custom carbon fibre dashboard
Lexan-windows (windshield original)
electric kill switches (outer and inner)
RJS safety window net
Lightweight dragrace steering rack and column (custom mounts and uniball rodends)
Moroso Quick release steering wheel adaptor
AbFlug steering wheel
As we have no good tracks in Estonia, this car should find a new home where there are glued track and someone can show the true potential of this beast.
I have driven it only 1 season - 60 starts !!! Can make a rebuild with new bearings or give evrything needed for a rebuild with the car!
Invested more than 60K £
pics can be found : http://suchen.mobile.de/fahrzeuge/details.html?id=76423171
For sale 41 000€
Markel
markel [at] baltifiltrid.ee
+372 521 5678
  • 2 weeks later...
I am not interested in buying this as i am currently building my own "Ultimate Street Drag Supra" (See link in my sig)
But i am Very interested in it being bought into the uk where it could hopefully achieve better et's;)
I am sure we would all like to see more pics and it will help with the sale.
Cheers
Stuart
  • 3 weeks later...
I have been talking lots with Markel through pm's picking his brains for my build and he is Very Knowledgeable.
Bump For Markel!
It would be awesome to see this run over here with a new enthusiastic owner ;)
Markel...Can you post anymore pictures or maybe a Youtube Video?
Hi ,
these girls are Latvian , but they look ok to me also :)
if anyone has not understood - they are not wearing bra :eyebrows:
here are some links of the car in action:
http://www.youtube.com/watch?v=yC4yvUKtDd0
Last one is the 9.3 run with 248kmh trap speed. A small wheelie :eyebrows:
Thanks for the bumps!
Someone buy this beast- so i can build a 2jz monster :cool:
Markel
  • 1 year later...
