Illuminated spark plug cover.
Guest jamesthejames
yup i upgraded the front bumper as i didnt like the stock one and always loved ts.
UPGRADED the bumper, are there lights to upgrade in the engine bay? the car had a bumper which i changed, there are no lights in the bay;)get what im saying...
Upgraded eh? :sly: Upgraded how? If it's fibreglass, it's a crapper material and small impacts will damage/destroy it instead of it flexing and shrugging them off. If it's not wind tunnel tested I'd say chances are the coefficient of drag is worse? What about the airflow through the rad and IC? Is that better? Maybe it fits the stock mounting points better..? Panel gaps tighter? Better ground clearance? Holds the undertray up nicely does it?
Or maybe none of the above and you just thought it looked prettier :) In which case that's a "swap" and not an "upgrade" ;)
And for what it's worth, the red lights look quite cool and it's hardly offensive to passers-by and other motorists, is it.
-Ian
Guest CoolsBlue
-Ian
its designed by top secret so has to be better:D airflow to the rad is way better than the stock i bet, and it looks the nuts compared to stock.
