na/tt starter motor?
broomie
  • 7 months later...
As I understand it, physically they will bolt up, but there is a difference in the cranking amps, the N/A has a higher compression ratio so requires more Oomph! from the starter motor, a TT starter on an N/A would probably work fine but may turn the engine over a bit slower, this comes from old memory :p so I'll wait for that to be confirmed or not.
poss...ive always seen 2 types, gold lable and green lable...both work fine though ;)
