Guest mabs Posted October 3, 2008 Share Posted October 3, 2008 Hi got a k reg supra tt when I drive it makes a rattling sound at the back by the boot herd its a common thing on supras but need to know how to resolve the problem any advise please and also got a very bumpy ride i dnt know if this is a common problem dnt no if its the shocks cuz the cars quite old or need to change the springs any help Quote Link to comment Share on other sites More sharing options...
little num Posted October 3, 2008 Share Posted October 3, 2008 hi mabs, what part of midlands you from, anyways the boot rubbers are normally the things to go on these, i have just changed mine and ive got a uk L REG, so if they have never been done id say these for deffinatly, problem is the bolts that hole them in are normally siezed like mine was and to be honest an absolute night mare to get the old one's off, good news is tho they only cost a few quid from toyota (stourbridge) i have part numbers if needed cheers again. Quote Link to comment Share on other sites More sharing options...
Paul Posted October 3, 2008 Share Posted October 3, 2008 If you do change the boot rubbers then do a search on here for the correct method of removing them, the bolts are loctited on not 'seized' and the best way to remove is with a little heat. Quote Link to comment Share on other sites More sharing options...
3LL Posted October 3, 2008 Share Posted October 3, 2008 yep, deffo the rubbers on the lip of the boot me thinks! Quote Link to comment Share on other sites More sharing options...
bigbloodyturbo Posted October 3, 2008 Share Posted October 3, 2008 as said before the bolts are blue loctited on, when i took mine off, the loctite was so thick on it you could barely see the threads. I used a hot air gun on them, not to hot but heated them for a fairly long time to let the loctite get warm, even with that i almost round off the head of one of them. Good luck bud. Quote Link to comment Share on other sites More sharing options...
snake Posted October 3, 2008 Share Posted October 3, 2008 I just cut the rubber off and undid the screws with molegrips Quote Link to comment Share on other sites More sharing options...
flukey-lukey Posted October 3, 2008 Share Posted October 3, 2008 Or if you can't be arsed to get new rubbers and fit them just smear a little bit of vasaline on them Quote Link to comment Share on other sites More sharing options...
snake Posted October 3, 2008 Share Posted October 3, 2008 Arsed and vasaline in the same sentence:d Quote Link to comment Share on other sites More sharing options...
flukey-lukey Posted October 3, 2008 Share Posted October 3, 2008 my bad Quote Link to comment Share on other sites More sharing options...
Guest mabs Posted October 4, 2008 Share Posted October 4, 2008 lol cheers guys will do that asap n im from birms Quote Link to comment Share on other sites More sharing options...
