Lui's Single Turbo build
lui
Good to hear it's nearly there Lui, bet you're near wetting yourself in anticipation :D
I've been away for a while so might have missed something, but what was the cause of the misfire you had?
Misfire was due to doggy coil pack clip Ryan will be fitting all new ones today
great news mate, i hope all goes well today its in safe hands with ryan, you will still be crapping it when its on the rollers though:d
Cheers Gaz 6 hours to go now & will be putting vids + results up later :eyebrows:
  • Replies 283
Well just got back from great afternoon out @SRR with Ryan.G & Charlie there & fantastic results
508 BHP@fly wheel at 1.3 bar :eyebrows:
427 BHP at rear wheels :)
Around 500+ ft/lbs of Torque :eyebrows::eyebrows::eyebrows:
Perfect boost & torque curves with no lag AT ALL ;)
AFR's all perfect 11.1 on full boost & between 14.4- 15.3 on normal cruising
75% Duty cycle on the injectors
850 EGT's on full boost
Car just pulls & pulls + throws you back in the seats & quite scary what a difference compared to twins & hybrids :p
All set up done to these settings as Ryan did not want to push more power as much more to go due to keeping auto box safe :(
Pic's & vid's + dyno sheets will put up later once downloaded
Great drive home car sounds absolutely AWESOME & it FLY's !!!
Highly recommend the PHR Street Single Kit
Sure Ryan will put up his comments later too
Just want to say once again BIG THANKS to all the guy's at ToyotaGT for doing a amazing install & to Ryan.G for all the mapping & Charlie@SRR for doing the dyno
Edited by lui (see edit history)
