LED Door lights
Jellybean
Hey
my Supra is 1993 JSpec
If I wanted led door lights like on a Facelift Supra, how do you wire them up
Might as well do while I am changing the Front Speakers
Friends Facelift Supra has LEDs on the Door where the latch is, I assume this is standard with all facelifts?
are you guys talking about the little ring around the door lock? if so i have it on my pre facelift, it glows green when you pull the door handle.
that's what I thought as I have them on my pre-facelift (are these standard?)
But I've never seen the inner door ones, not a fan tbh. :)
there was a thread about it a couple of weeks ago, dont think they were standard, bit of hit and miss with them, some have them some dont, guess i was lucky!
The leds on the edge of the door i'm assuming could be wired to the green lock surround then, if not wired in then atleast it could switch a relay for the led strip.
