jacko Posted September 29, 2008 Share Posted September 29, 2008 Im not sure if my rear wheel bearings could be on their way out. When driving there is quite a loud sort of droning noise, but no squeaks or anything, so is it just that im not used to the road noise from wide tyres? Or could it be the bearings, but i cant hear any sqeaking or scraping noises, which i would normally associate with wheel bearing failure Quote Link to comment Share on other sites More sharing options...
monkey3 Posted September 29, 2008 Share Posted September 29, 2008 (edited) Does the noise change alot when changing direction. For example, if you corner right, if the noise gets loads louder then it could well be a left bearing. Also you could narrow it down with accelerating \ braking to the back \ front. If it's just a whirring noise that gets louder up to a point and then may go away, it could be a knackered tyre. Do you have decent tyres on the car? If not, why not? oh, also if the noise gets to squeaking \ scraping and it's a bearing, and you're still driving it, then you're either mighty brave... seriously, bearing whirring means you need a new bearing, bearing squeaking \ scraping means you've got a matter of minutes \ metres of bearing \ car left. Edited September 29, 2008 by monkey3 (see edit history) Quote Link to comment Share on other sites More sharing options...
jacko Posted September 29, 2008 Author Share Posted September 29, 2008 I wouldnt drive my car if the bearing was scraping or squeaking, but i have heard the noise before so i know what it is like Quote Link to comment Share on other sites More sharing options...
monkey3 Posted September 29, 2008 Share Posted September 29, 2008 Right-o Well, like I said if the noise changes alot when cornering, then it's more than likely a bearing. If it's a constant noise (pretty much) at a constant speed regardless of cornering, then it's more than likely tyres. What tyres have you got out of interest? Are they really old? Quote Link to comment Share on other sites More sharing options...
jacko Posted September 29, 2008 Author Share Posted September 29, 2008 They arent old, but they arent a brilliant make. I will be changing them as soon as i can, but im just buying a house, so moneys a bit tight. Theres plenty of tread on them, but i know that cheap tyres are often noisy Quote Link to comment Share on other sites More sharing options...
monkey3 Posted September 29, 2008 Share Posted September 29, 2008 Yes, that's the case... And tell me about it on the house buying... I would definitely be careful on rubbish tyres though. As a friend of mine always said to me: 3 most important things on a car are tyres, brakes and steering. Try some cornering anyway, doesn't have to be fast. Just a bit of right hand and a bit of left hand. Quote Link to comment Share on other sites More sharing options...
jacko Posted September 29, 2008 Author Share Posted September 29, 2008 Oh i totally agree, i have always ran either Toyos, Eagle F1's etc... but i bought a set of new 18's that came with tyres, so im just using them until i can afford to upgrade. To be fair they arent too bad, a bit twitchy in the wet, but i think thats more to do with the 3 litres and 2 turbos lol Quote Link to comment Share on other sites More sharing options...
monkey3 Posted September 29, 2008 Share Posted September 29, 2008 And the heavy right foot... Quote Link to comment Share on other sites More sharing options...
Matt _Aero top_ Posted September 29, 2008 Share Posted September 29, 2008 Which side of the car is it coming from ? And i know this sounds stupid but you didn't have the radio on did you with the electric ariel up ? Quote Link to comment Share on other sites More sharing options...
jacko Posted September 29, 2008 Author Share Posted September 29, 2008 Just sounds like a general drone from the back and no i didnt have the electric aerial up as my radio doesnt work lol Quote Link to comment Share on other sites More sharing options...
robin Posted September 29, 2008 Share Posted September 29, 2008 If its just a drone then its likely road noise. With big wide tyres there’s a lot more noise. If its a bearing the noise changes as the load changes like monkey says. Try jacking the car up and rotaiting all the wheels by hand; If they feel rough or notch and the pads aren’t touching the disk then the bearings are likely to be at fault. If you can grasp the wheel and wobble it slightly then it’s very very dead but I think you would know about it if they were that bad. Quote Link to comment Share on other sites More sharing options...
Luka-P Posted September 29, 2008 Share Posted September 29, 2008 Just jack the car up, grab a wheel and give it a shake. If it wobbles, your bearing is going or close to gone. Quote Link to comment Share on other sites More sharing options...
Dave Posted September 29, 2008 Share Posted September 29, 2008 ive just noticed i have a droning noise from the back end only noticable from 70 mph,cant be bearings just had mot ,what about rear axle fluid level ??? Quote Link to comment Share on other sites More sharing options...
Mcgoo Posted September 29, 2008 Share Posted September 29, 2008 Which side of the car is it coming from ? And i know this sounds stupid but you didn't have the radio on did you with the electric ariel up ? I thought I had a wheel bearing on the way out when I first got my soop, took a while to figure out that it was my arial!! Quote Link to comment Share on other sites More sharing options...
gordy07 Posted September 29, 2008 Share Posted September 29, 2008 I thought I had a wheel bearing on the way out when I first got my soop, took a while to figure out that it was my arial!! Explain please:) Quote Link to comment Share on other sites More sharing options...
