JamieP Posted October 9, 2008 Author Share Posted October 9, 2008 When i get a chance to book it in. Ryan or LeeP. Link to comment Share on other sites More sharing options...
Paul Whiffin Posted October 9, 2008 Share Posted October 9, 2008 Its available with 2 different size tanks, 1 gallon and 5 gallon, can't imagine where you would put a 5 gallon tank! Good bit of kit, I keep them in stock now if anyone else needs one. Link to comment Share on other sites More sharing options...
imi Posted October 9, 2008 Share Posted October 9, 2008 i've got the 1 gallon tank and still struggling to find a suitable place for it Link to comment Share on other sites More sharing options...
Paul Whiffin Posted October 9, 2008 Share Posted October 9, 2008 Boots the only place unless you have a stripped out interior and stick it in the back, might be able to fit it where the stock IC used to be possibly. Depends if you have anything else in there like an oil cooler for instance. Link to comment Share on other sites More sharing options...
imi Posted October 9, 2008 Share Posted October 9, 2008 I am thinking of dropping it in the boot (hope I dont hear the water splashing when driving) and the pump to go where the brake fluid reservoir is. I am going to use a CW SMIC so that location is not an option for me. Link to comment Share on other sites More sharing options...
heckler Posted October 9, 2008 Share Posted October 9, 2008 if you ask me, the only place to put the tank is in the boot, and no, you cannot hear is splashing around, mind you i cant hear much over the noise of the fuel pump! I would take a picture, but the car is at the body shop at the moment Link to comment Share on other sites More sharing options...
JamieP Posted October 9, 2008 Author Share Posted October 9, 2008 if you ask me, the only place to put the tank is in the boot, and no, you cannot hear is splashing around, mind you i cant hear much over the noise of the fuel pump! I would take a picture, but the car is at the body shop at the moment Supprised you can hear the 044, can only hear mine on prime, soon as the engine is started i cant hear it at all. Link to comment Share on other sites More sharing options...
heckler Posted October 9, 2008 Share Posted October 9, 2008 Supprised you can hear the 044, can only hear mine on prime, soon as the engine is started i cant hear it at all. i must have a quieter engine back on topic now... Link to comment Share on other sites More sharing options...
JamieP Posted October 9, 2008 Author Share Posted October 9, 2008 Maybe. my topic so ill change as i wish:D Link to comment Share on other sites More sharing options...
heckler Posted October 9, 2008 Share Posted October 9, 2008 Maybe. my topic so ill change as i wish:D so it is I cant hear mine from the outside, but i can on the inside... odd. has yours had sound proofing in the wheel well? Link to comment Share on other sites More sharing options...
JamieP Posted October 9, 2008 Author Share Posted October 9, 2008 Nah no sound proofing, do you think yours could be touching the bottom of the tank? its a big old lump the 044. Link to comment Share on other sites More sharing options...
heckler Posted October 9, 2008 Share Posted October 9, 2008 Nah no sound proofing, do you think yours could be touching the bottom of the tank? its a big old lump the 044. quite possible... hmm, guess I'll take a look at it at some point Link to comment Share on other sites More sharing options...
Kev.O Posted October 9, 2008 Share Posted October 9, 2008 Here's my efforts: Link to comment Share on other sites More sharing options...
imi Posted October 10, 2008 Share Posted October 10, 2008 Thx for the pics. I notice that the injector is plumped to the pipe right close to the bottom of the radiator, normally people go for the one closest to the Throttle body. Link to comment Share on other sites More sharing options...
DevilSupra Posted October 10, 2008 Share Posted October 10, 2008 Thx for the pics. I notice that the injector is plumped to the pipe right close to the bottom of the radiator, normally people go for the one closest to the Throttle body. aem installation manual tell to fit the injector on the pipe before the intercooler. This solution help to improve the cool effect of the meth Link to comment Share on other sites More sharing options...
imi Posted October 15, 2008 Share Posted October 15, 2008 aem installation manual tell to fit the injector on the pipe before the intercooler. This solution help to improve the cool effect of the meth so would this be the throttle body pipe or are you referring to the one just before the intercooler (the one that runs along the bottom of the car) Also, how is the injector mounted to the pipe, do you need an aluminum bung welded onto the pipe first? Link to comment Share on other sites More sharing options...
Kev.O Posted October 15, 2008 Share Posted October 15, 2008 so would this be the throttle body pipe or are you referring to the one just before the intercooler (the one that runs along the bottom of the car) Also, how is the injector mounted to the pipe, do you need an aluminum bung welded onto the pipe first? I believe it should be about two foot before the throttle body, usually after the FMIC, though as I'm running a SMIC I measured it. I drilled and tapped my injector into the pipework, though you have to be careful as there isn't a great deal of material to play with. Link to comment Share on other sites More sharing options...
Kev.O Posted October 15, 2008 Share Posted October 15, 2008 Here you go imi: Link to comment Share on other sites More sharing options...
imi Posted October 16, 2008 Share Posted October 16, 2008 Thx for the pic. I will see if I can get the injector plumbed on the pipe just before the intercooler (SMIC) that runs parallel to the radiator, else it will go in the throttle body pipe near the battery. Having mounted the water tank in the boot, I have run out of the water pipe that came with the kit. Can anyone recommend a suitable place where I can find either the same pipe of a suitable alternative? many thx Link to comment Share on other sites More sharing options...
