JamieP Posted September 28, 2008 Share Posted September 28, 2008 The water tank is huge, where have you mounted it? Link to comment Share on other sites More sharing options...
TrickTT Posted September 28, 2008 Share Posted September 28, 2008 In the boot, on the back of my sub enclosure, but in the spare wheel well would work just as well. Link to comment Share on other sites More sharing options...
JamieP Posted September 28, 2008 Author Share Posted September 28, 2008 (edited) I tried everywhere at the front of the car and it wont fit, i dont want it in the boot really, think ill just use the windscreen washer bottle now. Edit: just remembered i have to move/lose the washer bottle when the big inlet is fitted, looks like the boot is my only option then. Edited September 28, 2008 by JamieP (see edit history) Link to comment Share on other sites More sharing options...
TrickTT Posted September 28, 2008 Share Posted September 28, 2008 Depends where you are fitting the pump, but you could get a smaller bottle and put in place of the charcoal cannister. Link to comment Share on other sites More sharing options...
STU_3LTR_TT Posted September 28, 2008 Share Posted September 28, 2008 The water tank is huge, where have you mounted it?[/QU locate battery in the boot. Link to comment Share on other sites More sharing options...
imi Posted September 28, 2008 Share Posted September 28, 2008 same situation as you jamie. what about the pump and the injector nozzle, where are you guys mounting and locating those? I'l probably end up putting the tank in the boot too. imi Link to comment Share on other sites More sharing options...
heckler Posted September 28, 2008 Share Posted September 28, 2008 yup, my tank is in the boot, the pump is where the Charcoal canister was, and use the mid size jet - plumbed into the TB Link to comment Share on other sites More sharing options...
imi Posted September 28, 2008 Share Posted September 28, 2008 yup, my tank is in the boot, the pump is where the Charcoal canister was, and use the mid size jet - plumbed into the TB Hey Si...got any pics of the installation. Link to comment Share on other sites More sharing options...
heckler Posted September 28, 2008 Share Posted September 28, 2008 Hey Si...got any pics of the installation. not yet, gimme a week.. as I'm away from my car at the moment Link to comment Share on other sites More sharing options...
TrickTT Posted September 28, 2008 Share Posted September 28, 2008 Hey Si...got any pics of the installation. Some pics of my install [thread=143632]HERE[/thread] Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted September 28, 2008 Share Posted September 28, 2008 You can also mount the pump in the boot if you wish, WI is not effected by long pipe runs. Link to comment Share on other sites More sharing options...
JamieP Posted September 28, 2008 Author Share Posted September 28, 2008 Some pics of my install [thread=143632]HERE[/thread] Neat install. You can also mount the pump in the boot if you wish, WI is not effected by long pipe runs. Yea thats my plan now. Link to comment Share on other sites More sharing options...
imi Posted September 28, 2008 Share Posted September 28, 2008 Trick - thats a lovely install.....very clean and I really like the green led in the dash - nice touch. Whats the deal with putting the injector in the throttle side? what about the intercooler side? which one is better. Jamie - what size nozzle will you be using, medium or large? Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted September 29, 2008 Share Posted September 29, 2008 I use two jets with my Aquamist system, one near throttle body and one just after IC, good charge cooling and good in cylinder cooling;) Link to comment Share on other sites More sharing options...
JamieP Posted September 29, 2008 Author Share Posted September 29, 2008 Jamie - what size nozzle will you be using, medium or large? Small. Link to comment Share on other sites More sharing options...
imi Posted October 3, 2008 Share Posted October 3, 2008 Jamie Did you get this fitted already, if so, I would love to see pics of the installation. How is the kit controlled? Is this automatically hooked to the ECU (say AEM) and then once the temps increase above a certain threshold the water pump is triggered? Link to comment Share on other sites More sharing options...
heckler Posted October 3, 2008 Share Posted October 3, 2008 imi, Got a picture for you Obviously, the pump (where the cansiter thing was), little box in front is the controller, which takes a vac feed. The pipe is plumbed into the TB. The power is taken from the main fuse box, I used a spare slot with the appropiate sized fuse so no messy wires (couldn't do much about the pump wires ), and all the wiring if fed into the existing loom. I also have the warning light in the dash, I modified my L/H cluster with a custom warning light, which is a blue "WI" - if you want I'll take a pic of that. The tank is mounted in the boot, next to the boot light, with the water pipe and water level sensor down the passengers side of the car. Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted October 3, 2008 Share Posted October 3, 2008 I hope the AEM pumps are more heat tolerant than the Aquamist pumps, which don't like under bonnet temps. Link to comment Share on other sites More sharing options...
heckler Posted October 3, 2008 Share Posted October 3, 2008 I hope the AEM pumps are more heat tolerant than the Aquamist pumps, which don't like under bonnet temps. no probs yet, been under there for nearly 2 months. still works as advertised Link to comment Share on other sites More sharing options...
imi Posted October 3, 2008 Share Posted October 3, 2008 thx si for posting up the pic. Can you also post pics of where the injector is plumbed in? Advice: The only room I have under the bonnet hood is where the brake reservoir is. Would that be too close to the turbo. Link to comment Share on other sites More sharing options...
heckler Posted October 3, 2008 Share Posted October 3, 2008 here you go... (I have a modified TB ) Link to comment Share on other sites More sharing options...
imi Posted October 3, 2008 Share Posted October 3, 2008 that was a quick response.....what about the question about positioning of the pump - would it be ok if i mount it close to the brake reservoir (you have a black box in that area - maybe your alarm siren). Link to comment Share on other sites More sharing options...
heckler Posted October 3, 2008 Share Posted October 3, 2008 that was a quick response.....what about the question about positioning of the pump - would it be ok if i mount it close to the brake reservoir (you have a black box in that area - maybe your alarm siren). Cant see why not, just put some heat shielding around it if you think it might get too hot.. Link to comment Share on other sites More sharing options...
JamieP Posted October 3, 2008 Author Share Posted October 3, 2008 Not had a chance to fit mine yet. Link to comment Share on other sites More sharing options...
imi Posted October 9, 2008 Share Posted October 9, 2008 When are you getting yours fitted and by whom? Link to comment Share on other sites More sharing options...
