supraspeed Posted September 28, 2008 Share Posted September 28, 2008 ok ive got an apexi gauge/box with 3 gauges and i found out how to move the needles on the gauges- has this got anything to do with upping the boost on the "boost" one or is this something else? Link to comment Share on other sites More sharing options...
G-NEMIE Posted September 28, 2008 Share Posted September 28, 2008 (edited) moving your needles wont have anything to do with controlling your actual boost level If its the Apexi EL II Meter Control Unit. use the control box to setup warning levels for each gauge and to see what the gauges peek at https://www.injectedperformance.com/Images/Products/Med-249.jpg press the WARN button and if your warning light (red) shows , you will be adjusting the point at which the warning light flashes with up and down you can also show the peek of any individual gauge you can also replay 30 of Boost recording enjoy Edited September 28, 2008 by G-NEMIE (see edit history) Link to comment Share on other sites More sharing options...
