heater lights not working properly
add heywood
Apologies for not being clear. I mean the green lights (led's, status indicators) that show how fast the blowers are on, that indicate if you have your rear heater, air con etc, not the backlight. They do not work unless the backlights are on aswell.
Edited by add heywood
more precise decription (see edit history)
If you have had the dash off recently or in the past, check that the plugs at the back of the heater/AC panels(two plugs each with about 12 separate contacts on each one) are fully in.
After fitting my new radio about three months ago, recently the rear screen heater would not work nor would the indicator lights for that side of the push buttons.
One plug had not been fully located home........simple fix!
Rgds
George
Rgds
George
Might be worth a look, the dash was taken off the day I picked it up (couple of weeks ago). Connector may have come loose.
