Jim_1979 Posted September 27, 2008 Share Posted September 27, 2008 ANy isuues with the TT VVT-I engines? I remember reading about some tuning issues/limitations or something. I can't remember to be exact. Anyone got any info? Compared with a non VVT-I engine. Link to comment Share on other sites More sharing options...
Alex Posted September 27, 2008 Share Posted September 27, 2008 Tuning issues are only that with more sophisticated electronics you need to spend your money wisely on the ECU/mapping. Link to comment Share on other sites More sharing options...
johnny g Posted September 27, 2008 Share Posted September 27, 2008 I think the VVTi runs into a wall @ 520ish bhp IIRC - you need to start looking at cams etc, but should be fine up to that point. You need an ECU which can handle the VVTi; AEM does it, but only open loop. Solaris does it - and in closed loop, so I'd choose that. It's what I'm going for. I'm sure Ryan can advise better Link to comment Share on other sites More sharing options...
Alex Posted September 27, 2008 Share Posted September 27, 2008 I think the VVTi runs into a wall @ 520ish bhp IIRC - you need to start looking at cams etc, but should be fine up to that point. You need an ECU which can handle the VVTi; AEM does it, but only open loop. Solaris does it - and in closed loop, so I'd choose that. It's what I'm going for. I'm sure Ryan can advise better I don't agree, there is not such limitation on the cams. The cam duration will be *roughly* the same as the non vvti and people have managed much higher power levels with them. Link to comment Share on other sites More sharing options...
