VVT-I TT engines.... problems/limitations?
Jim_1979
I think the VVTi runs into a wall @ 520ish bhp IIRC - you need to start looking at cams etc, but should be fine up to that point.
You need an ECU which can handle the VVTi; AEM does it, but only open loop. Solaris does it - and in closed loop, so I'd choose that. It's what I'm going for.
I'm sure Ryan can advise better
I don't agree, there is not such limitation on the cams. The cam duration will be *roughly* the same as the non vvti and people have managed much higher power levels with them.
