ABS or Trac relay?
Guest lamw001
Hi guys,
This is the JDM 93 RZ auto that I recently acquired and still learning everything about the car. Could you guys please take a look at the picture to let me know if I am missing a relay or not? If I am missing one, which relay it is? (Sorry, it's got label on the back of the cover but I am unsure of the right direction.) Currently, there isn't ABS indicator when the ignition is at on position. Trac indicator will come up when I press the button down.
http://img411.imageshack.us/img411/6176/dsc5352questionnq9.jpg
Any help would be greatly appreciated,
Maverick
The lid of the relay box should tell you whats what mate yes that the abs unit . you have a dry solder joint which they all suffer from by the sound's of it , If you turn the key to second position and look at the right hand side of the dash you should get two oil symbols and the abs light up this is in the small window on the dash surround .?
Edited by supra matt (see edit history)
