miko_supra Posted September 24, 2008 Share Posted September 24, 2008 Has anyone ever checked their timing on the supra? Quote Link to comment Share on other sites More sharing options...
Jake Posted September 24, 2008 Share Posted September 24, 2008 Which timing? Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted September 24, 2008 Share Posted September 24, 2008 Timing light? Quote Link to comment Share on other sites More sharing options...
Soop Dogg Posted September 25, 2008 Share Posted September 25, 2008 That's an interesting question, actually. I know the procedure to do this, but the equipment will be different these days to what I used to use. I used to use a decent timing light to check ignition timing, with an inductive clamp around the HT lead to No1 spark plug. But since the advent of plug-top coils, I haven't had the need to check this. The ECU should keep a good enough check on the ignition timing to negate the need for a timing light, but if I wanted to check the timing just to satisfy my own curiosity, I don't know what the latest type of HT pick-up even looks like these days! (Ashamed to say that as it was always such a basic piece of equipment to have in my toolkit) I think I'd probably be able to hack my old timing light around to make a pick-up to fit the new plug-top coils. Quote Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted September 25, 2008 Share Posted September 25, 2008 Some of the inductive timing lights will pick up the low tension feed to the coil, used to use this method on my old S14. Quote Link to comment Share on other sites More sharing options...
Homer Posted September 25, 2008 Share Posted September 25, 2008 Some of the inductive timing lights will pick up the low tension feed to the coil, used to use this method on my old S14. This is what I did. Just opened up the plug on the ignitor and connected it to one of the wires there (can't remember which one now!) Quote Link to comment Share on other sites More sharing options...
absz Posted September 25, 2008 Share Posted September 25, 2008 This is what I did. Just opened up the plug on the ignitor and connected it to one of the wires there (can't remember which one now!) its the GREEN one:) Quote Link to comment Share on other sites More sharing options...
