Keeps Cutting out
Guest WOW
Hi, having trouble with my 94 Jap spec NA, when you come to a stop in traffic etc it will some time cut out, rev counter just drops to zero and it stalls, is this likely to be the idle control valve? Ive taken it out and cleaned it, but to no avail. Dont really fancy buying a new one if its not likely to be that as there a bit expensive! Any help much appreciated,
Thanks
Check for any vacuum leaks, particularly the small vacuum tubes for any splits. Do you have any 'bling' pipework on there?
Nah no bling for me! only thing other than standard is a K&N, i couldnt find any vacumm leeks tbh, might have a more indepth look tomorow, its just odd how it intimitent
Have a very close look, but you shouldn't find and leeks in there :p The vac lines can get brittle if they are old and a little fracture can cause it to stall.
Check the line to the MAP sensor especially.
Are there any other issues at the same time; does the dash all still work correctly (i.e. the engine just stops) or is it a total power fail?
I don't like the sound of your car, intermittent speedo, cuts out at idle.... have you had it long? Hope you get to the root of the issues soon, and cheaply! :)
P.S. Whereabouts in Worcester are you?
Cheers for all help, will have a closer look today
SteveR, were just outside Worcester near Bromyard, have had the car about 3-4 years now, its only the engine that cuts not all the electrics
Cool, about 20 mins from me (Malvern) then I reckon. You should come to a meet sometime. Check out the Midlands event section. :thumbs:
