rob wild Posted September 25, 2008 Share Posted September 25, 2008 (edited) I see. Are you not going to put it on the Rollers before you throw all this money at it, just so you atleast know how much of a difference its all made. Unless youd rather not know? Unfortunalty Axle i think your a bit behind the times with the Matt H saga. Matt's engine set on fire a few weeks ago so I would think the BHP is roughly and this is only an estimate 0BHP However before the fire and in the beginning the car produce 410BHP on a Rolling road day at Hyper and that was with 440cc injectors + hybrids etc. On that day I was in the dyno encloser and saw the dyno trace map for the AFR going all the way down to 13.5 afr @ nearly 1.4bar. Which is obviously dangerous for the engine. Unfortunately Matt push it a bit hard shortly after that and melted a Piston Then the car went to TF for a engine rebuild then came back up to Hyper for mapping as Matt had got new (hybrids on long story) 550cc injectors and a EMB. The engine then produced [email protected] . However to my mind and IMO I can't see why the car was producing more power! as the map if you can call it that did not include any "mapping" above 3000rpm and the car ran 10 afr or potentially lower. Even at 1.4bar again looking at some dyno print off i saw at hyper whilst Matt's car was in there. So TBH I would have though that the original figure of 411bhp was due the lean afr and now it was running a much safer 10 afr (although a tad to rich IMO) but still using the same boost pressure, dyno etc so I would have not been surprised if the figure would have been less. I wonder how "tweakable" the dyno was at Hyper Anyway its all in the past now! Edited September 25, 2008 by rob wild (see edit history) Quote Link to comment Share on other sites More sharing options...
AndyT Posted September 25, 2008 Share Posted September 25, 2008 Unfortunalty Axle i think your a bit behind the times with the Matt H saga. Matt's engine set on fire a few weeks ago so I would think the BHP is roughly and this is only an estimate 0BHP However before the fire and in the beginning the car produce 410BHP on a Rolling road day at Hyper and that was with 440cc injectors + hybrids etc. On that day I was in the dyno encloser and saw the dyno trace map for the AFR going all the way down to 13.5 afr @ nearly 1.4bar. Which is obviously dangerous for the engine. Unfortunately Matt push it a bit hard shortly after that and melted a Piston Then the car went to TF for a engine rebuild then came back up to Hyper for mapping as Matt had got new (hybrids on long story) 550cc injectors and a EMB. The engine then produced [email protected] . However to my mind and IMO I can't see why the car was producing more power! as the map if you can call it that did not include any "mapping" above 3000rpm and the car ran 10 afr or potentially lower. Even at 1.4bar again looking at some dyno print off i saw at hyper whilst Matt's car was in there. So TBH I would have though that the original figure of 411bhp was due the lean afr and now it was running a much safer 10 afr (although a tad to rich IMO) but still using the same boost pressure, dyno etc so I would have not been surprised if the figure would have been less. I wonder how "tweakable" the dyno was at Hyper Anyway its all in the past now! :blink: Some bad luck there. Quote Link to comment Share on other sites More sharing options...
j_jza80 Posted September 25, 2008 Share Posted September 25, 2008 I went 6 speed for strength but I do miss the auto in traffic I have to say My last car was a BPU+ uk spec, and I miss the autobox in some respects (around town, effortless overtaking on the motorway etc) The power delivery of a manual single is completely different, but more involving and rewarding. Quote Link to comment Share on other sites More sharing options...
Matt H Posted November 6, 2008 Author Share Posted November 6, 2008 Cars off to Michels tonight so approx 2 months time now and i should be back on the road, only been a year now since i last drove her properly! Anyway, to the months ahead ...... Quote Link to comment Share on other sites More sharing options...
Dr_Doom Posted November 6, 2008 Share Posted November 6, 2008 Good luck matey! Hope it goes well! I expect a ride in it once you get it back Quote Link to comment Share on other sites More sharing options...
magictorch Posted November 6, 2008 Share Posted November 6, 2008 Good luck with it all Matt, you could do with some:D Quote Link to comment Share on other sites More sharing options...
Matt H Posted November 7, 2008 Author Share Posted November 7, 2008 Good luck matey! Hope it goes well! I expect a ride in it once you get it back Course bud Car went off today, so i should be getting a pretty ace xmas present this year!! Quote Link to comment Share on other sites More sharing options...
paul mac Posted November 7, 2008 Share Posted November 7, 2008 so i should be getting a pretty ace xmas present this year!! no way, nothing beats novelty boxer shorts and a 4 pack of socks Quote Link to comment Share on other sites More sharing options...
supra matt Posted December 23, 2008 Share Posted December 23, 2008 Any up dates or pics on this Matt ? must nearly be there now? . Quote Link to comment Share on other sites More sharing options...
Matt H Posted December 23, 2008 Author Share Posted December 23, 2008 Any up dates or pics on this Matt ? must nearly be there now? . Michel was going to put a thread up but it hasnt materised as yet. I needed a new block so that put things back a bit but should be getting the car back towards the end of Jan No no pics as yet. Quote Link to comment Share on other sites More sharing options...
