Blue smoke
miko_supra
Could also be Valve Stem. Its the typical blue smoke issue. A lot of info on this if you search.
As far as I can figure its the Valve Stem if you see blue smoke when setting off from a stop and the occational puff at startup. Its the turbo seal if you also see smoke on boost and in general any other times that when setting of from a stop (when the engine as been on vacuum)
OK i checked the intercooler pipes turbo side and intake side and they seem to have just the same about of misty oil in them as they always have.
I've done a compression test as i am getting a smell of fuel in the oil. http://mkivsupra.net/vbb/showthread.php?t=162883
It's definatly only smoking when the engine is revved...never on start up or idle
Ok, doesn't sound like the stem seals. For it to be them, you would puff after idleing shortly. Fx when you move off from full stop or stop light.
Bit weird since i would think turbo seal would leave a moderate amount of oil in the IC pipes
Is it not possible that the turbo seal on the exhaust/turbine side could have failed, thus just putting oil into the exhaust rather than the compressor side...If that is possible, im not to clued up on the construction of these turbos
well reading on the forums it seams that i have a turbo seal problem. i'll write the next bit up to help any others that might stumble across the thread in the near future with similar issues...
The problem...
When i come to a rolling stop i get white smoke coming out of the exhaust, as well as after a little blip from the throttle.
Tests...
No smoke on start up so it isn't the valve stem seals
Compression test suggests piston rings are fine and the head gasket isn't leaking.
No mayo in the oil cap and the water in the radiator is holding steady so no cracks in the block either.
Pulled the intercooler hoses off and there is no excessive oil deposits in there and the spark plugs were also in good condition- no white deposits, which would indicate oil getting into the combustion chamber. So there isn't a leak on the turbo compressor side.
Which leaves me to believe that the turbine/exhaust side of one of the turbos is leaking oil. I'll pull them apart in the week to see if im right, and then its probably a hunt for some j-specs before santa pod!
you wont see a lot if you are thinking of inspecting the turbo's mate
your compression results suggest possible that you have valves leaking so could still be valve stem seals/worn valve guides, i had funny symptoms from mine but ended up being that
But i dont get any smoke on start up and my spark plugs show no signs of oil contamination
my plugs showed no signs of oil contamination, randomly smoked on start up
you cannot diagnose your car from forum responses you still have to do some work :( otherwise you will find ppl throw answers at you from everywhere and you spend money fixing things that arent broke. That said it "could" be turbo seals but smoking is sometimes a can of worms
leak down test will give you an accurate answer on your compressions, maybe you can get a borescope to inspect bores for scoring.
My van was smoking like mad too, not on start up but when it warmed up. No excessive oil in the intake pipes either.
I removed the intake pipe to the turbo, I could feel that there was a fair amount of radial play on the shaft so I fitted a reconditioned turbo which fixed the problem.
Boroscope would be fun :D anyone know of a place that supplies cheap ones. I dont think work would let me borrow one
  • 7 months later...
The problem...
Tests...
Hi Mike,
I was wondering what it turned out to be ?
I have a similar problem, any help appreciated .
Thanks,
out of interest how much is it to do the valve stem seals
AFR Tuning have the tools to do it without taking of the head for approx £500+VAT. Great service and a lot of experience in one place (Dude & Muffleman).
I am glad I approached it this way, as my problems are more than the valve stem seals.
