what settings suspension?
FuR
hi all
i recently had the tein super street suspension fitted and i want a firm ride, its adjustable and i just wondered what you would recomend to have it on
at the moment it is 6 adjustments from the hardest setting, do you think i should go even more?
bit of a strange question this but any comments would be appreciated
I have mine set on the hardest purely for the reason that its also set on the lowest at the moment. I don't intend to keep it this way because its far too unpractical and uncomfortable for me, but I'm too lazy to get it booked in with a suspension guru so he/she/they can set it up right :)
I also don't know any suspension experts in my area, so it means I would have to travel and probably stop over somewhere :(
Just experiment with it and try to find out what setting suits you best
SS normally has 16 adjustment settings for compression/rebound damping, if you only have 6, then something is not quite right.
hi
mine does have 16 settings, i was just saying that mine has 6 more settings to go before it is the hardest
