Paul372 Posted September 22, 2008 Share Posted September 22, 2008 Hi i ve brought some hid's hb3 9005 4300k ones for driving beam and i now know where i am going to hide the ballasts under the headlights but how do you install them exactly is it just a matter of plugging them in and turning on your lights and there done. I ve tried to search for a thread about installing hid's but cant find anything showing you through it step by step, so if someone wouldnt mine talking me through the process please step by step that would be wicked thank you Link to comment Share on other sites More sharing options...
AndyT Posted September 22, 2008 Share Posted September 22, 2008 They are plug and play bud. I've had a couple of problems with them not lighting, but the larger plugs on the loom supplied can be turned around. Reverse polarity. This does not damage anything. As long as you do not touch the lamps themselves there won't be a problem. Link to comment Share on other sites More sharing options...
Paul372 Posted September 22, 2008 Author Share Posted September 22, 2008 so there just plug in and light up, what if they dont light up what do i have to cheek what problems did you have with yours and do you have to up the headlight fuses Link to comment Share on other sites More sharing options...
Terminator Posted September 22, 2008 Share Posted September 22, 2008 No need to touch fuses, HID's are said to draw less power than standard bulbs. You will need a relay kit if you go for HID mains. Link to comment Share on other sites More sharing options...
Paul372 Posted September 22, 2008 Author Share Posted September 22, 2008 Terminator said: No need to touch fuses, HID's are said to draw less power than standard bulbs. You will need a relay kit if you go for HID mains. i got hid's for normal driving beam so i need a relay kit for them to work, where do i get one of thos from and whats it for how do you wire that up Link to comment Share on other sites More sharing options...
AndyT Posted September 22, 2008 Share Posted September 22, 2008 No mate only for main / high beam. Normal dipped should not require the harness. Fuses are 15A standard. Plenty for the HID. If the lamps or lone of the lamps doesn't light, take the plug out of the ballast and turn it 180 degrees. Or if it's easier turn the plug through 180 on the lamp itself. It's the larger plug not the smaller ones. Link to comment Share on other sites More sharing options...
gordy07 Posted September 22, 2008 Share Posted September 22, 2008 Let us know how you get on paul! Link to comment Share on other sites More sharing options...
Jamesy W Posted September 22, 2008 Share Posted September 22, 2008 Just a matter of plugging them in and slotting the bulb into the light, if you are tight for space this can get a wee bit tricky. Then it's simply a matter of turning on your lights. Link to comment Share on other sites More sharing options...
Sted Posted September 22, 2008 Share Posted September 22, 2008 All i did with mine was pluged them in, bolted the hid units to the lip on the chassis under the head lights and it was job done. Link to comment Share on other sites More sharing options...
Paul372 Posted September 22, 2008 Author Share Posted September 22, 2008 ok cheers guys i will give it ago tomorrow and let you know how i get on Link to comment Share on other sites More sharing options...
Luka-P Posted September 22, 2008 Share Posted September 22, 2008 Loosen the three(?) screws where the bulb twists into if it doesn't come out or go in all that easy. Link to comment Share on other sites More sharing options...
Paul372 Posted September 23, 2008 Author Share Posted September 23, 2008 right i ve tried to fit my hid's i got, i plugged them in cheeked all the conections seems all good turn them on and nothing there not lighting up so unplugged them plugged them back in and tried again and still nothing so i tried the other plug that they came with and still no luck lighting up, the ballast are not even getting warm or nothing do you think i ve got a dud set these are the ones i ve got: http://cgi.ebay.co.uk/9005-HB3-4300K-Genuine-Xenon-Hid-Conversion-Upgrade-Kit_W0QQitemZ230292310820QQcmdZViewItem?hash=item230292310820&_trkparms=72%3A12%7C39%3A1%7C66%3A2%7C65%3A12%7C240%3A1318&_trksid=p3911.c0.m14 Link to comment Share on other sites More sharing options...
phat supra Posted September 23, 2008 Share Posted September 23, 2008 hope you get some more answers mate fitting mine to night Link to comment Share on other sites More sharing options...
Paul372 Posted September 23, 2008 Author Share Posted September 23, 2008 phat supra said: hope you get some more answers mate fitting mine to night hope you have better luck than me, what ones did you get Link to comment Share on other sites More sharing options...
Paul372 Posted September 23, 2008 Author Share Posted September 23, 2008 what do you think both of them cant not be working i thought at these one would work, should i send them back Link to comment Share on other sites More sharing options...
Jamesy W Posted September 23, 2008 Share Posted September 23, 2008 Switch the wires round, had this problem myself. Just turn the plug around. Link to comment Share on other sites More sharing options...
AndyT Posted September 23, 2008 Share Posted September 23, 2008 Turn 'em round as said before. Link to comment Share on other sites More sharing options...
Paul372 Posted September 23, 2008 Author Share Posted September 23, 2008 R i get what you mean now, the plugs thats connect together not the wires coming out of the ballasts, Cheers guys all done now and working. Hid the ballast under the headlights in the front bumper and the little tip about loosen the three screws on the back of the headlight where the bulb goes in was a good tip the blubs where well hard to get in. Thanks again i dont know what i would do without you guys cheers, just got to wait till it gets dark now to get the full affect cant wait Link to comment Share on other sites More sharing options...
AndyT Posted September 23, 2008 Share Posted September 23, 2008 Nice one Paul. Link to comment Share on other sites More sharing options...
Paul372 Posted September 23, 2008 Author Share Posted September 23, 2008 Big thanks Andy dont know how i would of done it without your help cheers Link to comment Share on other sites More sharing options...
phat supra Posted September 23, 2008 Share Posted September 23, 2008 Paul372 said: hope you have better luck than me, what ones did you get http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=140257754995 these ones they both work but the bulbs are a real bad fit the body on the bulb is far to big for the hole tryed un do in the screws but am still not happy with them i am on j spec lights when i orderd the kit i stated that any idears anyone Link to comment Share on other sites More sharing options...
AndyT Posted September 24, 2008 Share Posted September 24, 2008 phat supra said: http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=140257754995 these ones they both work but the bulbs are a real bad fit the body on the bulb is far to big for the hole tryed un do in the screws but am still not happy with them i am on j spec lights when i orderd the kit i stated that any idears anyone From the lamps he's holding in the pics, they are close. Some, if not most, lamp holders need one of the tabs trimming so it will engage in the socket. If you look straight down at the lamp, lamp pointing at you, it's the lower right tab that is usually too large to fit. Needs reducing by about half. Compare it to the standard lamp. HTH Link to comment Share on other sites More sharing options...
spidermonkey Posted September 24, 2008 Share Posted September 24, 2008 phat supra said: http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=140257754995 these ones they both work but the bulbs are a real bad fit the body on the bulb is far to big for the hole tryed un do in the screws but am still not happy with them i am on j spec lights when i orderd the kit i stated that any idears anyone I have some of these coming, i have already fitted a different set so i will let you know if they are wrong or not when i get them. Link to comment Share on other sites More sharing options...
phat supra Posted September 24, 2008 Share Posted September 24, 2008 spidermonkey said: I have some of these coming, i have already fitted a different set so i will let you know if they are wrong or not when i get them. called them today looks like i have the wrong bulb but that have been goog and the new ones will be with me tomorrow Link to comment Share on other sites More sharing options...
monkey3 Posted September 24, 2008 Share Posted September 24, 2008 Got mine today, so bookmarking this. Link to comment Share on other sites More sharing options...
