Got my Hid's but where to mount the ballasts
Paul372
My friend and I had a couple of problems with mine, mainly do to the battery/stock airbox.
We took the headlights out and installed under them on the frame by the inner centre sections, effectively under the light. We had to put two on each side as I've got the fogs and dipped beams done as HID's now.
If you go single and move the battery, you've got it made a lot easier, as there's a lot more room!
There's loads of room under the passenger side headlight but very little under the drivers side, just enough room for my ballast which wasn't as big as some. You could fit it behind the headlight but that's only possible if the cables are long enough.
Best to take the headlights out and have a look.
