So here I go again.
SUPRALOOPY
800/1200/1500/3000 grit w&d, soapy water, machine polish with g6/g3/finesse and finish with plastX. A bit ott I know but it works. Oh and plastX on the inside and buffed with soft mutton and then microfibre cloth.
Dave;)
So most of the yellowing can be found on the outside I take it.
  • Replies 51
Yes. I find that when you wet flat the plastic it looks like nicotine staining in the water, after a while that goes and you know you are winning. With the process I use I also remove the small scratches that happen. I'm sure you don't need to go as mad as I have but believe it or not its quicker to do the ruff to smooth paper, as you are not rubbing for ages to it down to a smooth finish.
Dave:)
