boost controller
madwoody1
i'm in the market for a boost controller as car is over boosting in cold weather, but there are so many out there so i'm not sure which one to get so what i'm after is a little help in finding the right one, any views on controllers would be great is there any benefits in buying the expensive one? cheers for the help
Based on the very popular B-Spec., the all new PRofec B-Spec. II, electronic boost controller is equipped with new easy-to-use features at an economical price. In addition to the two presets, remote switch option and wastegate response adjustments, the B-Spec. II also includes: built-in back-lit LCD, which can display real-time, peak, or last boost (in either kPa or PSI), an optional warning and (BOOST LIMIT) functions and a larger capacity inline solenoid valve for higher boost levels.
this one says it can control boost limit
Basically your car with the exhaust and 2nd cat removed will boost to a certain base level eg. 1bar. A boost controller can only raise the boost from this base level, eg. 1.1bar, 1.2bar, 1.3bar etc. It cannot reduce the boost to less than the base level figure.
