vibration at front
Guest david
hi first thing in the morning i set off to work and i start to have a vibration at the front left side i think and as u slow down and brake it gets bad car vibrates a bit and steering wheel but after ten Mins of driving it goes then for the rest of the day it is fine it only seems to do it in the morning or when it has been sitting for a long time any ideas :(
sounds like caliper sticking to me.
Mine does the same, but in the morning I don't get it( notice it ), proberbly because of slow speed.
When I leave work I go straight onto a motorway and it feels as thou the front tyres give a slight speed wooble. It dissappears within a mile, as thou the tyres have got a bit of heat and balanced/expanded, its very light and hardly noticable, but annnoying none the less;)
i think it can be break discs?!?!
If it does when you aply the brakes!!! but it can be something else!! but it will be my 1st option to check them!!
prob skim them and you will see if it helps!!
discs are a bit worn but ok pads are almost new.it gets worse when braking but vibration is there when not braking?will try wheel bearing:(
  • 2 weeks later...
OK it is now getting very bad so i said to myself when i get home i must look at it so pulled up and i noticed when i Pres the brake peddle it sounded very creaky like floor boards then went to undo wheel nut and noticed wheel and disc and callipers on both sides were very hot and only drove it 5 mile away from work so i think it is the callipers sticking back is OK any other i dears it could be:search:
master cylinder some one said but back is ok
