Blue screen of death laptop help
Terminator
The laptop I use for all car related stuff, that has all my RLTC stuff, all my AEM files and years of techical data is dead.It wont start, it just cycles through safe mode etc. Start up gets into Windows XP pro start, the blue screen flashes for a fraction of a second and the whole process sarts over. Can I get my data off the drive????? any ideas???? help please??? anyone???:(
dont panic. The data has not gone. You will be able to get it back again.
Worst case we take the drive out of the machine, put it in a drive caddy and plug it in USB to another computer and get the data that way.
The first thing to try though is to press F8 as the machine boots up to get a boot menu up. Then choose Safe Mode and see if that works. If it doesnt then you could try 'last known good configuration' and see if that helps.
Give me a shout if you need any more help.
All ready tried those John, same loop happens!!
It is possible (through a lot of fiddling with setup files) to get it back working, or if you can put up with it you can get the important data off and just get the whole thing rebuilt from scratch.
The fiddly part usually takes me about an hour but needs the Windows XP CD and the original administrators password.
Infact if you put in the WIndows XP cd, boot up from it and there is a Repair option from there. May be worth a go.
Unfortunately it never came with a CD. The best option is to get the data and rebuild the system if it is worth it. Got a new message now
1720-smart hard drive detects immient failure ( failing Attr : 05)
Not having a lot of luck our main desk top just gave up. Fortunately I got all data onto a USB drive last night.
I think I may be in the market for a new lap top with a RS323 port I heard the Samsung R700 was a good machine.
not sure how good you are on computer things, but if you buy a 2.5" hard drive caddy from http://www.scan.co.uk or http://www.dabs.com, then take the hard drive out of the laptop, put it in the caddy and plug it in to a USB port on a computer it should find the drive and you can simply copy everything off.
I come home via the A1 at Huntingdon if that helps on the handover thing. Im very discreet in my recovery of data too :eyebrows:
JB
