Konrad Posted September 19, 2008 Share Posted September 19, 2008 Was going through various news today and found this little one: http://www.fit-pc.com/new/ Looks like nice alternative against some more sophisiticated car audio systems Around 170 pounds for version with Ubuntu preloaded sounds reasonable too There is also dedicated UK site http://www.fit-pc.co.uk/ with fit-PC (suprise suprise) for 199 pounds + vat Quote Link to comment Share on other sites More sharing options...
JamesC Posted September 20, 2008 Share Posted September 20, 2008 What would the sound quality be like coming from that? Also would the 500mhz Geode be fast enough? How would this compare to say a normal AMD K6 500mhz processor? Specs: Hardware CPU: AMD Geode LX800 500MHz Chipset: AMD CS5536 Display: Integrated Geode LX display controller up to 1920x1440 Memory: 256MB DDR 333MHz soldered on-board Hard disk: 2.5” IDE 60GB Ports: 2 x RJ45 Ethernet ports 100Mbps 2 x USB 2.0 HiSpeed 480Mbps RJ11 RS-232 (cable supplied) VGA DB15 Stereo line-out audio (headphones) Stereo line-in audio / Mic Quote Link to comment Share on other sites More sharing options...
Konrad Posted September 20, 2008 Author Share Posted September 20, 2008 There is tech spreadsheet on this site. I wouldn't expect this stuff to be lightning speed one, but it should be enough to play mp3/mp4 and be used as a satnav. A lot depends from operating system and drivers used I would believe There is also 512 MB ram version avaliable Quote Link to comment Share on other sites More sharing options...
JamesC Posted September 20, 2008 Share Posted September 20, 2008 Just did a quick search on Google and systems such as THIS came up which is a similar price but seem to be higher spec, this one has a 2.2ghz AMD Sempron, 5.1 sound outputs etc. How does a touch screen take the feed to the computer? Edit: THIS one already has GPS, TV and radio built in. Quote Link to comment Share on other sites More sharing options...
Konrad Posted September 20, 2008 Author Share Posted September 20, 2008 Ah but of course there will be more car PC's on the market, I just pointed this one out because of his size, power consumption and reasonable price. I believe that touchscreen is getting connected to VGA port and USB port to be fully functional Quote Link to comment Share on other sites More sharing options...
ivan Posted September 20, 2008 Share Posted September 20, 2008 How does a touch screen take the feed to the computer? USB - so that's one of the two available taken up straight away. That means for anything useful (wifi, GPS, camera, memory stick etc) you'll need a powered USB hub too. Quote Link to comment Share on other sites More sharing options...
JamesC Posted September 20, 2008 Share Posted September 20, 2008 After having a quick look around last night, it seems there isn't much choice when it comes to getting a double din sized VGA touch screen, unless you want to pay over the top for one. But then i guess it isn't a cheap stereo alternative. Quote Link to comment Share on other sites More sharing options...
Konrad Posted September 20, 2008 Author Share Posted September 20, 2008 USB - so that's one of the two available taken up straight away. That means for anything useful (wifi, GPS, camera, memory stick etc) you'll need a powered USB hub too. There is 3 USB ports there and i do belive wifi is built-in already Quote Link to comment Share on other sites More sharing options...
ivan Posted September 20, 2008 Share Posted September 20, 2008 There is 3 USB ports there and i do belive wifi is built-in already Two USB and no WiFi on the Fit-PC. However, the Fit-PC SLIM does have 3 and WiFi. Quote Link to comment Share on other sites More sharing options...
Ric Posted September 20, 2008 Share Posted September 20, 2008 http://www.mkivsupra.net/vbb/showthread.php?t=162496 Quote Link to comment Share on other sites More sharing options...
