Boost controler question
wile e coyote
Shouldn't make any difference with yours being vvti.
Basically, you set the target boost and go for a drive, once it sees a stable boost pressure signal, it will go into self learning mode and stay there, but there are many complicated bits you can do after that which I don't understand. I've got the instruction manual as a .pdf. PM me your email addy and i'll send you a copy.
