Rocker switch
Markie
Link to the switch I have.
http://www.maplin.co.uk/Module.aspx?ModuleNo=44877&TabID=1&source=15&WorldID=&doy=7m3
It says it illuminates. Does this mean it will light up when its switched on or all the time?
Trying to wire the damn thing in and blown 3 10A fuses already :swear:
Anyone have an idea on how to plum these 3 pin switches in so that it works to run the fogs on and also lights up when the switch is set to on.
After returning from the garage I had an idea of wiring it up like the following: Power from when the lights turned on connected to PIN 1, wire to fogs on PIN 2 (Which Works) and then before I had an earth connected to PIN 3, but now I think it should have a feed off PIN 2 to light the LED inside the switch..
Any have ideas on this stuff?
markie..........my switch is a 3 pin unit and i have a live from dimmer switch a wire to the fogs and the other 1 is earth
its also a little light on the swith as well but that just comes on no other wiring needed
take a pic of the back of the switch...on my swith it sed what wire had to go where
