NA Compression Test
Dazzi
With NA engines you have to take the whole inlet manifold off to take the spark plugs out. Obviously it will be a right pain having to connect everything back up just to get the reading from the 2 underneath it. Would it be ok to do the compression test without refitting the manifold? This is basically like holding it at WOT but im concerned any vacuum lines running into the manifold may have an effect on the final reading.
BTW what is the average compression on an NA as they have more than TT's?
Cheers
