R-TT Posted September 13, 2008 Share Posted September 13, 2008 Ok, my clutch is starting to slip and im just wondering what the best option to go for is?? I have a tt 6sp full bpu, fmic, mines ecu etc rolling roaded at 384bhp at under a bar of boost, since then fitted apexi boost gauge and running 1.2bar my question is.....is it worth fitting a standard clutch? will it last? at the moment i probably wont be upgrading much more but u never know in the future i have seen this one: Item RPS Max Series Clutch Kit for 1993-98 Supra TT Half way down this link : http://www.powerhouseracing.com/Templates/frmtemplateM7.asp?SubFolderID=5&SearchYN=N any1 used this or have any other options? for this king of cash cheers Quote Link to comment Share on other sites More sharing options...
harley-jm Posted September 13, 2008 Share Posted September 13, 2008 I would put in the RPS since you need to replace the clutch anyway. I put in a RPS Street Max and havent regretted it. Good for 500bhp and nice and smooth and not too firm. I also took the opportunity to put in a lightened flywheel which makes the throttle response alittle nicer but is embarrasingly noisy at idle.Re: clutch, you may have 384bhp now (where standard clutch should be fine) but I'm sure you may upgrade the power further later and you dont want to go back and do the clutch again..... cheers Quote Link to comment Share on other sites More sharing options...
R-TT Posted September 13, 2008 Author Share Posted September 13, 2008 thats what i was thinking, didnt wanna do the same job twice. just didnt know which brand/one was best to use. cheers for your reply Quote Link to comment Share on other sites More sharing options...
Nic Posted September 13, 2008 Share Posted September 13, 2008 (edited) If you're running stock turbos I would replace with standard OEM clutch, as it's the smoothest, quietest and easiest to use, plus usually the cheapest option too. Aftermarket clutches designed to handle more power are generally noisy, heavy and grabby in comparison. Aftermarket is not always better, especially true when it comes to clutches. Edited September 13, 2008 by Nic (see edit history) Quote Link to comment Share on other sites More sharing options...
supra dan Posted September 13, 2008 Share Posted September 13, 2008 i agree with nic i had an RPS it only lasted 3000 miles. swapped for a stock toyota and not had any problem since Quote Link to comment Share on other sites More sharing options...
Terminator Posted September 13, 2008 Share Posted September 13, 2008 If you're running stock turbos I would replace with standard OEM clutch, as it's the smoothest, quietest and easiest to use, plus usually the cheapest option too. Aftermarket clutches designed to handle more power are generally noisy, heavy and grabby in comparison. Aftermarket is not always better, especially true when it comes to clutches. I have an OS Giken clutch with a slightly lighter flywheel, it is light,smooth, does not grab, but rattles like a bitch:d, it amazingly strong. Quote Link to comment Share on other sites More sharing options...
Paul Whiffin Posted September 13, 2008 Share Posted September 13, 2008 Stock clutch for definate. Quote Link to comment Share on other sites More sharing options...
steb9780 Posted September 13, 2008 Share Posted September 13, 2008 Or maybe one of Chris Wilsons modified stock clutches? Quote Link to comment Share on other sites More sharing options...
Ian R Posted September 13, 2008 Share Posted September 13, 2008 Have a RPS carbon carbon on mine as Nic said is noisy but so far has proved to be bullet proof (touchwood) Quote Link to comment Share on other sites More sharing options...
harley-jm Posted September 14, 2008 Share Posted September 14, 2008 Interesting - those recommending the stock clutch - what is it good for in terms of max bhp + reliability? Suppose it depends how you drive/what you are using it for? thanks P Quote Link to comment Share on other sites More sharing options...
Nic Posted September 14, 2008 Share Posted September 14, 2008 Interesting - those recommending the stock clutch - what is it good for in terms of max bhp + reliability? Suppose it depends how you drive/what you are using it for? thanks P It can handle BPU power levels on stock turbos. Unless you running aftermarket turbo or using the car on the track, I would personally always go with a stock clutch. Quote Link to comment Share on other sites More sharing options...
R-TT Posted September 15, 2008 Author Share Posted September 15, 2008 whats the one cw does? what power are they good for? i assumed the stock was at its limits at 400bhp???? no?? Quote Link to comment Share on other sites More sharing options...
Luxluc Posted September 16, 2008 Share Posted September 16, 2008 Before going single, I had my car running full BPU - stock euro-spec turbos running 1.4 bar - with OEM clutch. Worked very fine Quote Link to comment Share on other sites More sharing options...
SJMKIV Posted September 18, 2008 Share Posted September 18, 2008 Would the stock clutch work well if I do full blown starts with my bpu supra? or power shift a lot? or would you then recommend a aftermarket clutch for street use, like the rps or act Quote Link to comment Share on other sites More sharing options...
Luxluc Posted September 18, 2008 Share Posted September 18, 2008 Unless you don't put at every red light half an inch of rubber on the tarmac, the stock one will be fine (condition : it is still fine and not used through age). If you plan to do drag strips twice a week, then go for an aftermarket clutch. Quote Link to comment Share on other sites More sharing options...
Nic Posted September 19, 2008 Share Posted September 19, 2008 Would the stock clutch work well if I do full blown starts with my bpu supra? or power shift a lot? or would you then recommend a aftermarket clutch for street use, like the rps or act If you're doing this a lot then then I'd go for something like the TRD uprated disc and TRD clutch cover. http://img299.imageshack.us/img299/4543/48857281fq5.jpg Quote Link to comment Share on other sites More sharing options...
