Heater and Aircon Unit
bolarbag
If I only want the standard heating and cooling functions of the sup, taking off the air con pump and ancilliries, what can I remove from the unit behind the dash?
The Evaporator, expansion valve, evaporator temp sensor, the A/C unit block joint,
What about the blower motor, I gather that needs to stay
What about relays, the magnetic clutch relay
Its safe to say air con won't be going back into this car, as the alternator is taking its place
